Question about Cell Phones
Boot loader message. How do i start the phone? soft reset won't work.
SOURCE: Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Posted on Aug 26, 2009
ur fortune
  • 85 Answers
SOURCE: My phone won,t start at all....
this is because of software problem........kindly connect to the computer and formatt your phone or flash your phone............this will re install the software your phone and your phone will be all right......k
Posted on Oct 25, 2009
SOURCE: Screen Message: Boot Loader....OK to Program USB
hold * and # and Power On when the phone is off..do this two times if first time not solves the problem. If you still have the problem it means the soft is broken and must be implemented again
Posted on Oct 29, 2009
asber
  • 291 Answers
SOURCE: Boot Loader 03.E0
probably you had pressed the bootloader buttons.
once the phone is diplaying a status message like you are having, it means that the phone is ready to be flashed. if you haven't do anything to your phone after displaying the message, try to remove the battery and put it back on. but if you had this status message during flashing, it will give you the same issue even if you remove the battery.
take care.
Posted on Feb 28, 2010
SOURCE: Hp rx4540.How to access the Boot loader mode??
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Posted on Mar 11, 2010
No power light, smartphone does not boot at all.
There is a way to do a Master Reset on MOTO Q phones that cannot access the standard Master Reset method:
  1. Power off the Q
  2. Press and Hold the Center Select Key, while powering up the phone
    or
    Press and Hold the Z & E keys, while powering up the phone
  3. The MASTER RESET screen will appear
  4. Press Yes
  5. This will restore the phone to factory settings
Jul 03, 2013 | HTC Amaze 4G
No gsm
check its imei *# 06# if it is start00 it may work by cdma if it start with 35 it may be gsm.visit any unlock centre ask for country unlock code.
Apr 09, 2010 | i-mate JasJam Smartphone
Stuck on boot loader,phone code sig error v3i r47a_g_08_d8_89r''
I Charged the battery up using another motorola phone,and then I did a software upgrade, and this has fixed the problem.The phone is working great now,all photos or videos were saved.
What i think caused this error is that the phone was doing an upgrade and then I got a message at the same time,I think these clashed some how and prevented the upgrade from completing,hense causing an error on the boot loader.
Hope I helped
Chris
Dec 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Oct 29, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My phone won,t start at all.... I am a total newbee on this. Can you please help me (in a simple way)? This is the message on the phone: Boot Loader 0A.52. SW Version: R3443H3_G_0E.C4.21R PH SIG ERR:...
Oct 25, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Was attempting to update windows mobile and it froze up and won't reset to regular screen
You might try hard resetting your phone:
Hold down the two softkeys (the ones with the white dots) and keeping them pressed, insert the stylus in the soft reset button hole. Keep all the keys pressed and it shall hard reset your phone to the factory settings.
NOTE: Hard resetting will delete all your data and restore the phone to factory conditions.
Sep 22, 2009 | HTC PPC-6800 Smartphone
Asus p320 Wont Boot anymore! help :(
Try this
"do hard reset:Press Right Soft Key and tap Reset at the same time, then please first release reset and hold the Right Soft Key, After P320 is powered-on , clean boot prompt picture will show on screen.Currently, you can release Right Soft Key. Follow the dialogue’s message, you can press “SEND key” to start clean boot or press “END key” to cancel clean boot.
Sep 10, 2009 | Dell Axim X50v Pocket PC
Spv m3100 re boot
Have you tried doing a hard rest. Here is the procedure;
Caution if you perform a full reset, your phone returns to its default settings and looses all information that is saved on phone (Like contacts, messages, emails, mms etc).
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
May 01, 2008 | Orange SPV M3100 Smartphone
Hx2750 Touch screen
you said you tryed soft and hard resets..
Check the bootloader if it has a diagnostic function, my HTC model has many self tests build in the bootloader, so give it a try on yours.
Boot Loader Hold down the left, second from left and second from right buttons whilst pressing reset button
waiting for your reply.
Dec 23, 2007 | HP iPAQ H1940 Pocket PC
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
