Question about Mitsubishi Heating & Cooling
What does it mean when the mrchi remote controller stops communicating with the transmitter for a Mitsubishi Mr. Slim, but everything else works fine? Do these controllers go out?
We have a Mitsubishi Mr. Slim split system that was installed four years ago. No problems this whole time and then a few days ago, the remote controller went rogue on us. We can't turn the a/c system off, even after replacing batteries and turning off the breaker to that unit. There are no error codes too. The only thing we've noticed is where the transmitter says connect on the inside, there's a red light, not flashing just constant.
  • 7 Answers
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
SOURCE: Bose Cinemate Home Theater
same prob, the tech was no help wants me to send in 75 bucks and pay for the shipping
Posted on Apr 28, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 27 Answers
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Posted on Nov 26, 2008
picatudo
  • 239 Answers
SOURCE: fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Posted on Jan 04, 2009
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
The remote control for a Mitsubishi Mr. Slim unit was lost. How do I find a replacement? What info do I need to find the correct controller? Thanks
Mike you can find an OEM replacement a the following link. To get the right one, you will need the model # of the one you lost. If you don't have that, you acn call or email the company for assistance.
http://remotecontrols.com/index.php/mitsubishi
I hope this helps you and thanks for choosing FixYa.
Sep 19, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a quad mitsubishi mr slim unit. one of the units was on during a power outage. We were not home so we did not see what happened but when we returned, the unit that was left on has the vent still...
Try to turn all of the power off for a few minutes and then turn it back on...this should reset everything again...
If not you will need to get a tech. to check it all out...
Here is a tip about Mitsubishi Air Conditionersand how to get the manuals for all of the Mitsubishi line. The manual includeboth troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Jul 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
When srart the unit from remote control 1)indoor unit running 3to4 min and then stop automaticaly. 2)i canot get 12vDC output for outdoor unit. this is mitsubhisi airconditioner please explain about this...
its verry simple if your compressor did not run with in 5-10min it mean it has a defective thermal fuse....
cos the thermal fuse is the protective current for the ciol winding of the compressor.
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Remote control does not work, Cannot controk u nit. Unit 6 mos old. New batteries in remote.
probably faulty remote control, or faulty control card in unit.try pushing the test button inside the indoor unit near the electrical cover
Apr 22, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
What do the mode icons on remote control for Mitsubishi Air Con mean? Thank you.
change from what operation you want the a/c to do like fan only or cool only or heat only(if it has heating) or auto if you want auto change between heat and cool
Aug 01, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim split system with no display on remote control or unit display.
Mitsubishi Mr slim comes with no diplay on the indoor unit but there is small display on th eremote unit.for further help kindly send your air conditones complete model
Jul 09, 2009 | Heating & Cooling
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
41 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
