EWF1282 Washer won't start. No display. No power on. Power supply in outlet is ok. Vic Joaquin Philippines
SOURCE: Whirlpool Duet washer, about 1
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
Posted on Mar 27, 2009
SOURCE: Kenmore elite top loader washer won't start.
Actually I didn't need a solution. The unit would not start. It was like no power was coming in. The outlet was good and usually if there is a power failute the unit flashes PF. Well I walked by in a couple hours later and and touched the start button and it worked. Got two loads of wash in. It must
have a loose connection or a dirty connector, but I'll wait until it happens again
Thanks
Posted on Jun 24, 2009
  • 8 Answers
SOURCE: No power showing on display
its the fuse, its located under the dishwasher. take off the bottom white plate, its on the right side of the pump on a wire harness. Its in a fuse cartridge turn to the left take out fuse and replace with 15 amp fuse take it radio shack and have it matched.
Posted on May 06, 2010
walesarumi
  • 6993 Answers
SOURCE: washer wont power up. Outlet and breaker checked
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 11, 2011
  • 5603 Answers
SOURCE: my digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Posted on Sep 16, 2011
Washer won"t turn on outlet is working
If the washer won't start, the user control and display board or the main control board may be defective. The main control board failure is not common. Check other parts and causes first.
If there is power to the display and the machine wont start, check that the door is latching properly as there is a switch in the door latch that tells the control board when the door is properly closed. The switch might be faulty.
Feb 16, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Plugein but no power
Check power outlet is working by trying another appliance, if it is ok you will need to either get a qualified engineer to trace the voltage through to see where it's failing. If the power outlet and flex are ok next step is the on/ off switch, and any fuses/safety cut outs . Alternatively if you disconnect it you can check continuity with a test meter . Caution high voltages when connected to the outlet.
Apr 18, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Lg wf 760
please follow the steps and fix it. God bless you
her won't start, the user control and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
May 28, 2013 | Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Won't turn on
Check the power lead and the mains outlet.
If these are OK and when you press the power switch on the computer and the power LED does not light up then most likely the switch mode power supply is faulty.
Switch mode power supplies contains dangerous mains voltage and I do not recommend a DIY repair. Just purchase a new switch mode power supply, make sure the wattage of the power supply is equal or greater than the old power supply.
Apr 29, 2012 | Computers & Internet
Hp 65w adapter compatibility
no it will burn the power supply if half wave rectifier is used in adapter then it may work if you are not technical person then purchase new adapter or convert it from any technician
Nov 19, 2008 | Computers & Internet
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
