Question about Dehumidifiers
What are the recommended settings as far as % of humidity and room temperature? Does this set automatically?
  • 459 Answers
Humidity is said to be good at 50% RH and temerature at 77*F. Air looses humidity when it is heated or cooled. Extremely humid conditionals it difficult for air conditioners to cool the air.
The temperature to be comfortable in varies from person to person.
Posted on Aug 11, 2017
Testimonial: "And this is for settings on my dehumidifier?? I thought like 30% is what you want inside your house."
SOURCE: The dehumidifier is running but very little water
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
Posted on May 09, 2009
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
  • 289 Answers
SOURCE: Runs when it feels like it. If it is set at 60% it
i understand your my nead to relocate the unit to a central location.
Posted on Nov 26, 2009
  • 4736 Answers
SOURCE: I have a 50 series
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
Posted on May 17, 2011
  • 4736 Answers
SOURCE: I have a DDR7009EE and the fan runs continuously
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Posted on Jul 28, 2011
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
What kind of dehumidifier you recomend for a food processing room of about 3500 sf or 20000cf, the rrom temperature is 70F and the humidity is high. what equipment you recomend and what is the ideal...
An Air conditioner dehumidifies just by having it on. You don't mention what kind of food you process. It's hard to recommend without more information
Jan 24, 2014 | Dehumidifiers
Why does my dehumidifier run al the time ,i have the humidity set at 45 and when the room temperaturegoes down to 55 it keeps running.
The 45% setting is too low and the setting is never satisfied, so the unit keeps running to try and reach 45%. Try setting to 50 or 55, this is a very comfortable range. I was not clear on the room temperature being at 55 degrees. Is this what your thermostat is set to or is this the actual room temperature. Brrrrrrrrrrrr
Sep 01, 2011 | Fedders A7DH45B2A Dehumidifier
Will not regulate humidity correctly. I set it at 60% and it is still running when the humidity in room reads 45%. I have confirmed this with a separate humidity gauge.
It may just be the fan running and not the compressor. Some unit's are designed that way, so that air is constantly moving and when the humidity level rises above what you have it set on, the compressor will automatically turn ON and remove that moisture. Wants it's back to where you have its set, the compressor will turn OFF. Check your Owner's Manual to see if your model has that feature.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Comfort-Aire BHD-501 Dehumidifier
What setting should my Maytag be on.............Room Humidity or Room Temperature. I am getting no water in pail. I have Model number..........M7DH45B2A
If you want to remove humidity rather, than maintain what's in the household air at this time, You should lower the humidity setting well below what the LED readout shows. Usually 35 to 40% is the optimal setting.
Hope this helps you. Please let me know. Thanks.
Jun 07, 2011 | Dehumidifiers
What is the right temperature setting when the room has a lot of water?
You can't control the temperature setting but you can control the humidity level. I would start somewhere between 35 and 40%- making sure to empty the dehumidifier promptly when full. 40% humidity will prevent mold and mildew growth- and that musty smell- but keep the room from becoming too dry.
Mar 01, 2011 | Kenmore 54501 Dehumidifier
Just wanna know how to set the temperature on it
dehumidifiers do not have a temperature control, rather, they have a humidity control. usually you set the humidity control to go off when the level of moisture in the room reaches normal (approx. 25-35% winter;38-55% summer). Best way is to run it at full on for 1 to 4 days (until you know the moisture level is how you want it), then turn the knob until the unit goes off . This will be the ideal setting. Goodluck<Macgivor
Jan 16, 2010 | DeLonghi DDE40E Dehumidifier
What setting should I set my dehumidifier for % humidity when the room temperature is 68
I have a Provic dehumidifier mainly to remove damp from walls in my 1900s terraced house ( 3rd DPC failed, another on its way). I've read a lot about the technical side and all I wanted to know was 'do i set it on the highest or lowest % to extract moisture from the walls'. I rang the Managing Director at Provic (his contact details are given on their website) who was very helpful. He advised that the lower the setting, the more damp would be removed from the walls and therefore the air, as the water passes from the wall into the air. My DH ranges from 40% to 70% so he advised me to set it at 40% in the worst affected room to remove as much moisture as possible from the walls. As the moisture is removed, the DH will collect less water and set itself to the correct level anyway. He advised me that when as much water as possible has been removed from this room and the DH % will not drop any lower, to move it to a more central position in the house, such as the hallway to then start setting the rest of the house to the correct humidity level. I set the DH to 40% and left it on overnight closing all doors to the affected room and removing containers of water such as a vase of flowers. When I got up in the morning it had switched itself off as it had already collected 3 litres of water! You do have to be careful not to over dry the air as everything, furniture and electricals, naturally needs moisture, but for a short term, quick drying solution, this level is ok.
Hope this helps!
Jan 01, 2010 | Maytag Dehumidifiers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Humidity reading is 16% when actual humidity is 46%
Running a dehumidifier when the ambient temperature is to low will cause freeze-ups. Also running it when the dew point of the moisture in the air is to low will cause it to freeze up when you set it to low which would be a higher number on the set point.
The hand written number on the probe casing is probably a quality control inspector number.
May 04, 2008 | Danby DDR586R Dehumidifier
Dehumidifiers Logo
71 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Are you a Dehumidifier Expert? Answer questions, earn points and help others
