Question about Ovens
Oven gets warm but not hot? - Ovens
  • 5 Answers
This could be a thermostat issue or a burner issue. Most ovens have a top and bottom burner, if one of them is not working, the oven may not reach or stay at the right temperature. You should be able to get a replacement at home stores that sell appliances or order one online. They are fairly easy to replace. You may have to remove a couple of screws but otherwise they pop out and pop in. You can test the burners by turning the oven on bake and a few minutes later open the oven to see if the bottom burner is red, if not it may be burnt out. You can set the oven to broil and after a few minutes, look at the top burner, if it's not red it's likely burnt out. If both burners seem to be working, it is likely a thermostat issue. I haven't replaced one of them before, but you should be able to find instructions on youtube to determine if it is something you are comfortable replacing on your on.
Posted on Aug 11, 2017
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Nov 14, 2017 | Electrolux Ovens
Oven not getting hot
I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
Jan 13, 2012 | Frigidaire Ovens
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
My GE oven heating element heats red hot no matter what temp I put the oven on
Something is probobly wrong with the thermostat, it gets hot to warm up, but should lessen as it reaches your desired temp. If the thermostat is bad it will just keep going.
Nov 20, 2009 | GE Profile JTP18 Electric Single Oven
I have a Kenmore 9114012190 oven it does not heat properly anymore the top and lower elements get hot but it will hardly get anything warm that is placed in it ie; bread has to stay in it for 45 mins to...
start by checking your input power for a full 240volts,then check the terminal block for any burned off power input wires,then check power connections all the way thru the oven control and finally check for "hot-spots" in both elements(highly unlikely that both would be bad) its a discolored area that is a high resistance area not passing full operating power thru element(s)
Nov 19, 2009 | Kenmore 40192 / 40199 Electric Single Oven
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 16, 2009 | Smeg Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
