Panasonic blu ray; bp-87 firmware update, says its connected to wireless network. But never actually connects. Solution?
  • Computers & ... Master
  • 384 Answers
That issue is posted right on this Site Do A Search !!!
Posted on Aug 11, 2017
samrat
  • 10 Answers
SOURCE: updated firmware now connected access internet on other computer wireless
hi, there is nothing to worry..... all ya have to do is , ya need to try to connect with the unsecured wireless connection in order to check the functionality of the wirelees part. If it allows ya to connect, then ya need to log into the wless routers configuration page and go into the security option and choose the security--WEP(64 or 128 BIT)and make a note of the key which gets generated in the key coulmns, any one key- preferably the first key and save the settings. n when ya' try to connect with wless computer it will ask ya the security key , plz enter the same key on yor wless comp- the same key which ya ve noted down. "confirm the key"- same key. and it will show ya a staus "wless is now connected".
Posted on Mar 08, 2007
nliwilson
  • 114 Answers
SOURCE: Cannot connect iMac with DI-524 over wireless! Please help!
The most likely answer is that you have an access control list (MAC Address filtering list) set up on your router and have not added your Mac's MAC, also called your Airport ID to the list but there are other possible causes.
Double check that you do not need to add your MAC address to the list, that you did save changes when you removed security from your router and that your PC can still connect.
The hardest part of moving from PC to Mac is learning to trust your computer to do things for you, with Microsoft's OS's you don't just trust the automated set-up wizards because even in the rare circumstance that the wizard actually works you invariably have to finish the settings manually.
With your Mac the exact opposite is true, if you try to do everything manually it'll invariably mess things up, where as using the wizards and trusting the computer to manage things on it's own reaps obvious rewards.
If Airport set-up wizard is asking for a WEP key and leaving the field blank doesn't work you can be comfortably sure that the router has a key set up on it. (BTW: Always be mindful of the fact that WEP is pointless, even 128bit.)
Check that your router has not been hijacked and that you have indeed removed the security from your router, is it possible that you have a WPA key set up on the router? Unlike WEP, WPA and especially WPA2 actually secure your network (in as much as is possible).
Another major cause of connectivity issues for new Mac users is having Norton Internet security installed, for a PC user the idea of not having full-on paranoid security installed is anathema, the idea that your Mac's inbuilt firewall alone is plenty of protection (at time of writing) Other than that ClamXav antivirus will protect your Mac form any viruses that may appear in future. Norton Internet security for Mac is often pushed on buyers by stores that don't know any better, to be honest Norton Internet security for Mac is an awful lot of hassle and performance loss for little or no advantage.
Using a Mac is different to using a PC but once you have got used to using a Mac you will not be able to change back, once you have learned to trust your Mac to do things for you, you will find Windows (any version) to be painfully time consuming, unstable and fiddly to use.
Post back if you are still having problems. :)
Posted on Mar 10, 2008
SOURCE: 80010201 Error code and controllers won't connect
In the 60gig ps3 it was the CWI-001 board located under the sd mini sd/ cf / m pro board and above the usbs. I replaced mine and controllers, wired and wireless Internet work fine.
That fixed my problem I hope that this helps. Good luck
Posted on Sep 02, 2009
  • 567 Answers
SOURCE: how to connect two speedtouch modems wirelessly ?
  • Hi you need a wireless router to do this,
    PICK A ROUTER - There are tons of wireless routers to choose from. Depending on how big your house or office you might have to purchase multiple routers. The current standard in wireless technology is known as Wireless G. It is rated at a maximum speed of 54Mbps with a radius range of approximately 75'. This is most suitable for small homes or offices. Other types include Wireless A, B, and N and all vary in bandwidth and range. Do some more research and find out what might be suitable for your needs.
  • Step 2PICK A WIRELESS NETWORK CARD - If you set up a wireless network make sure to get wireless networking cards for each desktop, otherwise there'll be no way for you to connect to the internet. Most laptops have wireless networking cards built in, check your laptops manual to make sure.
  • Posted on Jul 21, 2010
    • 857 Answers
    SOURCE: I run a Linksys WRT300N
    Your primary router can be any brand of router - whatever you already have, for example. The DD-WRT firmware with wireless bridge mode need only be installed on the secondary router you're turning into a client adapter (we'll call it the "client router").
    This tutorial assumes that your primary router is, like most routers, assigning IP addresses by DHCP. Without DHCP enabled, your bridged peripherals may not be able to get onto the network.
    Take note of any wireless security currently enabled on your primary router. If you are using WEP, note your passphrase and key length (64-bit, 128-bit, etc.). If using WPA or WPA2, note your passphrase. Later, you'll need to input these on the secondary router.
    You will need to access the administration interface of the secondary router, your DD-WRT router. Obviously, you can't launch a web browser from your printer. For temporary setup purposes, you need to connect a wired PC to the secondary router. The easiest way is to grab a laptop computer, temporarily disable any wireless network it has, and connect it via Ethernet cable to one of the LAN ports on the secondary router. Do not connect it to the WAN, sometimes labeled "Internet" port, which can remain empty.
    Assuming your DD-WRT is set to factory defaults, its IP address is 192.168.1.1. We are going to disable its DHCP server, so you should manually configure an IP address for your temporary PC. A good choice would be 192.168.1.2.
    Step 1. To manually configure your IP address in Windows XP, click to Control Panel/Network Connections/Local Area Connection/Properties. Scroll down to Internet Protocol (TCP/IP) and click Properties. Now click Use the Following IP Address and enter 192.168.1.2 as the IP,
    255.255.255.0 as the Subnet Mask, and 192.168.1.1 as the Default Gateway.
    As for Windows
    , enter the IP address 192.168.1.1, Subnet Mask 255.255.255.0, and Router 192.168.1.1. Click "Apply Now" to save the changes.
    Step 2. Open a browser on your PC and connect to the DD-WRT router -- its default address is http://192.168.1.1. The default login is root and password is admin. Of course, you should change these. You probably won't, but our lawyers require us to say that.
    Step 3. Click Setup/Basic Setup. Scroll down to Network Address Server Settings (DHCP). Click to disable DHCP. This will prevent the bridged router from assigning addresses, which will be the job of your primary router.
    Step 4. Click Wireless/Basic Settings. For Wireless Mode select "Client Bridge." Set Wireless Network Mode to match your primary router - "mixed" is the safe default, unless your primary router is set exclusively to b or g mode.
    Step 5. Click Wireless/Wireless Security. For Security Mode, select the appropriate choice that matches your primary router - either none, WEP, WPA or WPA2. In this example, our primary router uses WPA security. The algorithm is set to "TKIP" on both routers, and we've entered our shared key.
    Step 6. Click Status/Wireless. Scroll down to the bottom of the page, and you'll see a button labeled "Site Survey." You now need to associate this router to your primary router to create the bridge.
    Click the Site Survey button, and a window pops up showing available wireless networks.
    In our setup, one wireless network with SSID bordella is available. That is our primary router. Click the Join button to create the association.
    DD-WRT will let you know that you've successfully joined the network.
    Step 7. You've now completed the bridge.
    To test it, you need to receive an IP address from your primary router. Revisit Step 1 and set your IP address back to automatic assignment. Unplug the network cable from your temporary PC, whistle a few times, and reconnect.
    Your temporary PC should receive an IP address assigned by your primary router. You can test this by opening a browser and connecting to an Internet web site.
    Posted on Oct 01, 2010
    Can't connect DPM-BDT100 to internet for firmware update
    Can you not connect your player to your computer, select the player through devices on your computer, put the CD in your computer drive and then select update player on your computer.
    http://av.jpn.support.panasonic.com/support/global/cs/bd/download/bdt100/bdt100_euro.html
    Jan 17, 2018 | Panasonic DMP-BDT100 Blu-ray 3D Player
    Panasonic dmp-bd655 internet connection problems
    hello!wrong, i have fixed this trouble with the 1.62 firmware available on panasonic official support site.but the only way to update it, is burning the file on a cd-r or cd-rw.
    greetings from paris, france.
    Nov 13, 2011 | Panasonic DMPBD655 Player
    My btt270's wi-fi has been working great for two months. I even started getting Netflix last week and now I keep getting a fail to connect/an internal error occurred during wireless settings. Clear...
    There was a firmware update a while back which I loaded. Nothing seemed changed but today I could not connect and got "an internal error" message.
    The solution: unplug the device, wait a minute, plug it back in. It loads the
    updated firmware (or reboots what you have) and everything works.
    Jun 19, 2011 | Panasonic Televison & Video
    Panasonic bd 60 plays standard dvds but having problem detecting blu ray discs working the other day just packed up blu ray disc not spinning where as standard discs do spin & work this disc player...
    You might have to update the firmware on it. This usually involves connecting the Player to the internet though your home network, and then in menu go to update. Best buy can do this for a fee if having trouble.
    Mar 12, 2011 | Panasonic DMP-BD60K Blu-ray/DVD Player
    Won't play the 2012 blue ray movie only the movie previews
    dudes really simple as i couldnt watch 2012 amazing movie !
    get a usb stick go to the site that is your make or model say for example: ( philips blu-ray bdp3000 go to philips and software and downloads after selected model )
    download the firmware open as winRAR or documents u should see the choice of two folders select them both and extract them to your usb stick and done !
    stick in your blu-ray player settings advanced software usb and download and wait should not take more than 2 mins for everything to be working !!!!
    Mar 15, 2010 | Samsung BD-P1500 Blu-Ray Player
    Is the LG BH200 compatible with Netflix on Demand?
    Straight from the box, no.... they discontinued that model and the next one that came out supported Netflix right out of the box.
    I do not think they offered a firmware upgrade that supported it either...
    I have the BP-150 which does do Netflix... My remotes have 4 colored buttons on the bottom that allow you to select Netflix, youtube, pandora, nad blockbuster...
    Connect it to the internet and see if you can update the firmware. Can hurt... well then again it can can't it....
    Peace,
    Mar 07, 2010 | LG Super Blu BH200 Blu-ray and HD-DVD...
    Problem connecting to my wep encrypted wireless linksys wrt150n wireless router
    Check the following things:
    1. Other PCs making a connection?
    2. Have updated to the latest firmware?
    3. Do you connect after removing the wireless encryption?
    4. Do you connect using a wired connection to the router (ethernet)?
    3. Do you get a connection when you connect directly to the modem (bypass the router)?
    If you can not connect after the above, chances are the unit is defective.
    Jan 03, 2010 | LG BD390 Blu-Ray Player
    Recommended blue ray players??
    The firmware upgrade issue for blu-ray players is one that is causing alot of consumers and enthusiasts alot of headaches. But upgrading firmware is not going to go away.
    Therefore, I would have to advise that for ease of use, choose one that has an option to connect to the network directly, such as Sony's BDP-S350. A network connected device will find the firmware upgrades itself so you don't have to find it and burn it and load it, etc.
    Oct 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
    Will not play new blu-rays
    You might need a firmware update on the player. just connect it to a network router with an ethernet cable. then there should be an option in your dvd player menu for updates.
    Jan 26, 2009 | Televison & Video
    Computers & Internet Logo
    David Payne
    David Payne
