Question about Cell Phones
Hoover SpinScrub 50 Model F5915905.
Need illistruations to swee whatunder hood is supposed to look like. Thank you for urs or pics or any help!
    Top Expert:
  • Cell Phones Master
  • 39,083 Answers
Check YouTube for something similar.
Posted on Aug 11, 2017
  • 126 Answers
SOURCE: need instructions for operation
The last time I checked, manuals were available on www.hoover.com.
Posted on Mar 21, 2008
  • 10 Answers
SOURCE: Floor Mate
There is a black shaft with a black circular arm at a right angle to the shaft. The black plastic arm that sticks out of the front ( farthest away from the hinge) of the roller assembly plugs into the circular arm so that moving the scrub/vacuum slider causes the roller assembly to move up and down. I can do it with my finger, or use a flat blade screwdriver. I'm assuming you mean the black plastic thing with the little rollers on it.
Kirk Thompson
San Juan, PR
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: Hoover model 5906-900 spinscrub
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
SOURCE: I have a hoover spinscrub carpet cleaner model
I just needed to clean the brushes I finally just found the clips on each side of the brush roller and pressed in towards center and was able to pull brushes out.
Posted on Mar 20, 2009
ginko
  • 19396 Answers
SOURCE: I have lost my manual for my Hoover SpinScrub
Hi
Here the manual:F5914900
Here parts and accessories.
Regards.
Ginko.
Posted on Jun 13, 2010
Testimonial: "Thank you very much!"
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How to remove hood from hoover carpet/upholstery cleaner model F5915905
Hello! Removing the hood is not recommended as it is factory sealed and may void your warranty. If you are trying to clean your nozzle we offer a nozzle clean out tool that can be ordered online by following this link > Nozzle Clean Out Tool If further assistance is needed you may contact our Customer Service Department at 1-800-944-9200 or you may reach out to us here on Fixya, Twitter @DirtDevil or facebook.com/dirtdevil. Hope this helps!
Jun 05, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Need to remove hood on F5915905 to fix upholstery nozzle
Hello! Removing the hood is not recommended on the F5915905 as it is factory sealed and may void your warranty. We recommend taking your cleaner in to a service center for repair. Follow the link to locate the nearest service center to your location. Service Center Locator Thanks!
Jun 03, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac modal # F5915905
I can tell you this you need to replace the hoses and seals that run through the cleaner and are used to carry the water from one place to the next and replace the sprayers to
Mar 20, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover SteamVac F5914-900 SpinScrub... The last time I used the hand tool attachment, it worked fine. Just tried to use it again, and now I only drips of water will come out of the hand sprayer,...
The brushes can be turned off on most of them via a switch on the hood. There shouldn't be water coming out onto the floor unless you are pulling the trigger at that top. You probably broke this when attempting to use the tools.
http://www.vacuummedic.com/product.php?id=231
Sep 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
