Question about Mitsubishi GPS
Torque settings rocker shaft assembly for mitsubishi 6m601at2 &valve clearane
Tom
mjsylvia
  • 3 Answers
SOURCE: 1997 mitsubishi torque specification
20Nm (14 ft lbs.)
Posted on Feb 01, 2009
  • 83 Answers
SOURCE: torque on rocker nuts
First of all, put down that torque wrench! It's BS that the mfr puts in there to cover their ***.
You'll need a 14mm and 10mm open end and of course a set of feeler gauges.
With the small nut loose set your gap ( .006 intake/ .008 exhaust +/- .001 on each). Once you got your gap, hold the large nut with the 14mm and tighten down the small one. Now check your gap again, it hard to keep from moving slightly and my take a few attempts. You want to make it snug but don't gorilla torque it.
Posted on Apr 02, 2009
Hentie
  • 18 Answers
SOURCE: specs for a 1997 Ford Ka 1297 cc
If the vehicle is fitted with a Rocam engine, the valve clearance is not adjustable, hydraulic lifters.
The camshaft caps are torqued in two stages, first 10Nm and than 90 degrees
Posted on Apr 20, 2009
steve_e_uk
  • 1675 Answers
SOURCE: can you tell me the torque settings on a rocker
on the 4.0 its , first tightning 3nm, second tightning 7nm and its the same for the 4.6 hope that helps
Posted on Feb 03, 2010
  • 49960 Answers
SOURCE: ENGINE TORQUE SETTING FOR ASSEMBLY ON MAINS,BIGENDS AND CYLINDER HEAD AND VALVE CLEARANCE
As you have not specified what engine , I suggest that a workshop manual for the engine would be a good idea as it will have all these details and other information that you will need down the track.
Posted on Sep 12, 2014
Factory reset gps
UNFREEZE Tom tom sat nav USING WINDOWS OR MAC PC
This will unfreeze your tom tom after exhausting every avenue this works!
You will need Internet access.
Ensure you have the correct tom tom desktop softwear installed on your computer for your tom tom device.
If not then download from tomtom
Removed sim card from tom tom located under sticker lower end of tom tom.
Carried out on a windows laptop with windows 7
(Note this should also work on mac although I did not get to try it and it is stated you will need rosetta on intel macs)
Ensure you download the flash tool for tomtom (clear_flash.dmg) for your operating system windows or for the mac VERY IMPORTANT YOU HAVE THE TOOL DOWNLOADED FIRST.
1.For windows: www.tomtom.com/updates/clear_flash/clear_flash.exe
connect tom tom to computer
find the tom tom on your computer and select all the files
you can firstly copy these to another location or separate drive before deleting all files.
Now delete ALL the tom tom files
Format your tom tom to FAT32 if using windows (im not sure of the mac settings yet)
Keep your tom tom connected to your computer
Run the flash tool and Flash the tom tom memory with the tool.
Restart your tom tom
It will update (but this time it should work!)
Select done after update
Tomtom reboots (restarts)
It may ask you to install a new update but there may not be any update to install just
Select yes to update.
Eject tom tom from your pc by selectinglower right corner symbol.
Now unplug device if ejected correctly
Congratulations your device should now work again.
Note I did not replace my sim card as it is not required to work the gps.
Hope this helped someone.
My device does not keep its settings What should do
Aug 14, 2014 | Tomtom TOM TOM ONE WE V3 GPS Receiver
My new iphone 3G wont pair with Tom Tom 520 - the tom tom finds the iphone, the iphone seems to find the tom tom, but iphone will not make full connection Any ideas please
i dont think the iphone will pair with the tom tom gps, because they use a different satellite & interface....iphone is running on Google whereas tom tom has its own satellite.
Mar 10, 2010 | Apple iPhone 3G
After having my tom tom for 10 months I finally downloaded the Tom Tom Home and updated my Tom Tom. However, after doing so, I disconnected my Tom Tom and it no longer works. I only have the Tom Tom front...
Probaly you're still within the gaurantee periode, go back to the store and don't tell them that it is you're own fault that you've bricked your tom tom, they only need to know that it stopped to work without anny reason, that this happend with normal use, they should replace it for you or send it back to tom tom to fix it for free.
Next thime don't unplug you're tom tom when it is updating, be patient,
the software tells you when it is finished updating.
Succes.
Sep 28, 2009 | Tomtom ONE GPS Receiver
Tried to update my Tom Tom One by connecting to my
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
Is it possible to update a gps tom tomgo 300 memory card
Have you gone to the tom-tom web site and downloaded the Tom Tom home? If not I would recommend that first. There are many upgrades and additions there. But I do not believe you can update the 300 without being connected to your computer via usb cable and being on the tom tom site with tom tom home downloaded.
Hope this helps
Mar 15, 2009 | Tomtom GO 300 GPS Receiver
My computer has wiped my tom tom one i now have a red cross how do i fix this
your tom tom should come with an update disk which should also include the orignal files that the tom tom runs with on the disk there should be a restore original files in the disk. if not then have a look on the tom tom website and see if they have an files you can download to restore the tom tom :)
Jan 20, 2009 | Tomtom ONE GPS Receiver
Tom Tom Handsfree
YOU HAVE TO MAKE THE PHONE ACCESSABLE (EG. PUT THE PHONE IN DISCOVERY MODE SO THE TOM TOM CAN FIND IT)
Mar 11, 2008 | Tomtom GPS
Tom tom 720 and imacs
my opinion is downloading was not successful again download
Jan 04, 2008 | Tomtom GO 700 GPS Receiver
GPS Logo
95 people viewed this question
Top Mitsubishi GPS Experts
ray gallant
Tom Chichester
Are you a Mitsubishi GPS Expert? Answer questions, earn points and help others
