Question about Campbell Hausfeld Garden
There seems to be excess water coming from the front of the pressure washer and I wanted to see where to start to fix this. I have a campbell hausfeld 1750psi standard duty unit.
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 384 Answers
SOURCE: PW1345 Campbell Hausfeld Won't run
Got gas?
Posted on Jul 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
  • 8 Answers
SOURCE: Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Posted on Aug 07, 2009
  • 73 Answers
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Posted on Oct 17, 2009
How to hook up a pressure washer by Campbell hausfeld
Hook up the water hose and plug it in I assume it is electric.
Oct 11, 2016 | Campbell Hausfeld Garden
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
I have a 3000 psi campbell hausfeld gas pressure washer and it has no pressue how can i fix it
Small stream sounds like your pump is not working at all - you are getting house pressure only. First check the intake fitting where you attach the hose for debris that may be clogging the water flow. Same for the pressure hose and quick connect fittings. Remove the tip from the wand and see how much flow you get. If it's still only a small amount, with the motor running, you probably have a bad pump. This can be caused by bad seals inside the pump, or by running the motor without maintaining water supply to the pump, which can melt the seals or even seize the pump if allowed for too long. Repairing the pump is typically more work and expense than replacing it, assuming you can locate a replacement pump.
Aug 03, 2014 | Garden
I have a campbell hausfeld 2450 pressure washer with water coming out of a brass hose nozzel right next to where you screw the high pressure to the pump as soon as you turn the water on from the house,...
this is called the chemical injector which enables you to insert the hose for you to dispense the soap and or chemical by utilizing a soap nozzle .apparently inside this barb you will find a ball a spring and a o-ring,find the replacement parts or kit from its manufacturer.finding a plug to replace it is not recommended due to the fact that the pitch of thread is hard to find.replace asap this unit relies on trap pressure to unload.
Aug 04, 2013 | Campbell Hausfeld Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Have a honda gvc 160 power washer. It works ok for a while then loses all pressure. It seems as though when it is not running and the water is attached there is not as much water coming through. Is there a...
Sounds like the machine is not getting enough water.
Please check your water pressure to the machine and also the water inlet filter in case its a little dirty.
Jun 16, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
C/H 1750 Washer will not start with water connected. Electric motor will start without water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Oct 30, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Garden Logo
42 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
