Question about Electrical Supplies
Preethi blue leaf mixer stopped working. The power on light is also not glowing/lighting. So, Opened the mixer, noticed white wire is just hanging connected nowhere. Other 2 wires are connected to circuit breaker. is the white wire supposed to be connected somewhere?
SOURCE: frigidaire compact 30 elec. stove.
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Posted on Dec 04, 2008
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
SOURCE: Wiring bath fan with Fan/ light combo. Want to
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Posted on Oct 26, 2010
cool78259
  • 228 Answers
SOURCE: I have a 12/2 (black/white/ground)
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Posted on Jul 10, 2011
canwoodjc
  • 3301 Answers
SOURCE: Purchased: Carriage House II
check this link for a diagram, http://www.wiringhelp.com/electrical/electrical-how-to/how-to-wire-a-ceiling-fan.html go down to the diagram with 2 switches,, click it, it will enlarge,
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Preethi eco plus mixie not working (first time)
I recently brought(just 2 days back) a Preethi ECO Plus mixie from India.(US made)
It works fine for some days when i use that to grind some soaked
rice it was working fine for some time, suddenly the motor is not running. But I can see the power light switched on in the mixie. But its not working.
I am not sure if there is some service centres for repairing these kind of issues.
I am located @phoenix ,Arizona,usa
please let me know.
Indira
May 13, 2013 | Preethi Nitro Mixer Grinder - 110 Volts...
Preeti mixie stopped working
I know it is kind of late to answer this, but those who are looking anew for a solution to this problem might find this helpful so writing my experience. I also brought a Preethi mixie, 110V from India and in less than two uses of about 5-10min it stopped. I searched everywhere for a solution and even called service center in Chicago (yes, there is one in Chicago, IL) and finding it difficult to go there and get it repaired, I dared to open it.
I am glad I did as I noticed a connector wire (with a plastic seal/insulator) is burnt. It is a simple fix and I cleaned the burnt part and carefully exposed the wire a little bit more and connected it back to the other wire as it is supposed to and put the insulator back in its place. I started the mixer and its working now :)
I have been using it for a month now since I fixed it to make dosa batter, chutneys etc and it is still working. So I think this is the problem most of us had with mixer not working after few minutes of usage and even the overload button not working. Try this and let me know if this solved your problem.
Happy Cooking!
Jan 13, 2012 | Food Mixers
On the hampton bay remote control fan and light module, i do not have wiring diagram. from my ceiling box, i have a red, a black, a white, and a bare copper wire. I think it is because the light switch has...
Unfortunately, Mark it's really not as simple as it sounds, to connect the wires properly. Because of that third red traveler wire for the 3-way switch. Actually, ceiling fans don't work well, when a 3-way switch is involved, because it was designed only for lighting convenience. When the fan is turned on, the other ceiling lights will start to glow, whether they are ON or not..
You would be much better served if you can locate another line to come off of and wire to that. Of course,y you won't have the convenience of a wall switch to operate it. But, that's what the pull chains on the fan are for.
Hope this helped you and thanks for choosing FixYa.
Sep 04, 2011 | Heating & Cooling
Hi, Our Indian made Preethi Eco Chef mixer had stopped working after pressing the overload button repeatedly, any idea whether any repair centers in and around Ipswich
Hi, please replace the Overload button (Circuit Breaker) with a new one. You can purchase the Overload protector (Circuit breaker) in any nearby Mixer repair or Electrical shop. Please take the old Overload protector to get the new one of same specification which suits for your Mixer.
Apr 16, 2011 | Food Mixers
95 ford f250 trailer wiring trouble what does each wire work and what color
The basic 4-flat trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights and White-Ground
7-way trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights, White-Ground, Red or Black-auxiliary power, Blue-Trailer Brakes and Purple-Reverse lights
Jan 15, 2010 | 1995 Ford F250
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
Electrical Supplies Logo
144 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
