Question about Tablets & eReaders
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
  • 5 Answers
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Posted on Aug 11, 2017
  • 358 Answers
SOURCE: how to connect wifi network in archos 28 internet
This is normal. To save energy, the ARCHOS always starts up with the WiFi set to off. You must manually use the Fn-F3 keys if you want to activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong? Make sure that your WiFi is activated. This can be turned on and off with the blue function key pressed down and then the F3 key. The blue WiFi indicator just below the touch-pad will light indicating that it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong? It could be that the WiFi modem/router is hiding its SSID. This is done for security purposes sometimes. You can either change this on the WiFi modem/router (see its instructions) so that it broadcasts its SSID (and then you'll see it in the list on your ARCHOS 10) or you can go into the advanced settings of the Wireless Network Connection screen to the Wireless Networks tab and 'add' a new connection. You will need to know the SSID name and its other connection parameters.
Posted on Dec 17, 2010
jomabug76
  • 1148 Answers
SOURCE: toshiba thrive wifi connectivity
u search wifi networks ,,should have in the menu wifi connections or add a new network,,do a search for wifi,,a wifi scan,,when new netwrks or signal s appear on there,,,if it says open u can go online,,if passwrd enabled or wep or psk or whatever u cant ,,has to be a open signal,,like mcdonalds,,hotels,,,stuff like that,,drive an d search,,
Posted on Dec 23, 2011
caroldon
  • 17130 Answers
SOURCE: my internet tablet keeps saying network problem when i try connecting to wifi
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart.
If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings.
make sure that your password and the network is connected as seen on the lower taskbar .
Posted on Jun 07, 2012
  • 7 Answers
SOURCE: wifi connection is slow
If the wifi network works fine with your laptop and not with your tablet, Then there must some problems with the tablet's antenna. Try for a replacement if it is new.
If the speed test gets hanged on your tablet, Try to test with any other source. For example, you can test the internet connection speed from www.scanmyspeed.com It does not require flash support too. So it has not much chances to get hanged.
Posted on Apr 27, 2013
SOURCE: connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Posted on Jul 11, 2013
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
It says that I have internet but cant get on the internet
Do you try to connect to the Internet when at home or away from home ? At home, you need to have a wireless (WiFi) network to connect your tablet to and then access the Internet from your tablet. Away from home you need to find an OPEN WiFi network (usually in public places such as coffee shops, bookstores, etc) to connect to. Or you can get an USB mobile/cellular modem from your cellular provider to attach to the USB port on your tablet and access the Internet at home and/or away from home (this option will cost you money). You also need to install on your tablet apps that will access the Internet (browsers, Pandora, Youtube, etc.).
Dec 09, 2014 | XO Vision Ematic eGlide 7Inch Touch Screen...
How do I unlock my ipad 4?
The term "unlocking" when it comes to iPad means either having a password to access the device, or a process to access and change the underlying operating system. The padlock icon doesn't have anything to do with WiFi. Also, if you cannot connect to WiFi, you cannot get to Facebook, Google, or anywhere else on the Internet, in the same way that if you car wont' start, you can't go to work or your buddy's house. Your root problem isn't that your car won't go to your friend's house, it's that it won't start. SO, please re-ask the question with specifics of your root problem, which is you can't connect to WiFi. Do you know the password for your WiFi router? Can you see it listed in the wireless networks? Do you not know how to connect to WiFi in the first place?
Sep 13, 2014 | Apple iPad Wi-Fi + 3G - Tablet - iOS 4 -...
Tablet problems
there are some tips on WiFi connectivity in the FAQ pages on the Maylong website. This might help. Start setting up the wifi connection next to where the router is located. Once the connection is made then try to move around. Hopefully this will help.
http://www.maylonggroup.com/support_tablet.htm
Aug 10, 2014 | Maylong Tablets & eReaders
I can't internet on this computer
This looks to be a WiFi only tablet. Do you have a WiFi access point to connect to or have a free one somewhere like WalMart/MickyDs etc. You then need to make sure your WiFi is turned on your tablet and then connect to the access point. Once connected you can use a browser to access the internet.
Mar 10, 2014 | Visual Land Connect 7" Tablet
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
Jun 11, 2013 | Tablets & eReaders
Can't get access to internet web sites
Are you connected to a WiFI network? You'll need to be in order to access the internet. Some WiFI networks (in hotels, often) allow you to connect but not use the connection unless you pay a fee.
Hope that helped!
Jan 22, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
70 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
