Question about Breville Blenders
Breville whizz? n do you start the processer and not blender
5 Suggested Answers
  • 619 Answers
SOURCE: blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Posted on Jan 14, 2008
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
Posted on Jan 21, 2009
Posted on Mar 04, 2011
  • 1631 Answers
SOURCE: Vita-Mix 5000 blender shuts off under heavy blending loads.
Compared to the ordinary blender or the imitators of VitaMix, you have/had a wonderful unit. Others would die immediately if users tried to do with them what is done daily in a vitamix. We have had ours for already going on 18 years or so, the 5000 and it still works great. We just upgraded though and have the 750. Now we have 2.
Customer service is and has always been a great help.
Contact Us Customer Service Vitamix
My opinion is the blade assembly in the container, is the problem. The bearings and/or seal is locking up and in turn the motor of the base has to work harder. You will need a special wrench to get off the blade and replace the assembly. I would start there.
Check this out:
Vitamix Wrench
Posted on Mar 16, 2015
Jug for a Breville Blend Master modelBLR- 3
Call the manufactor or e-mail the company they'll have it.
Jan 10, 2013 | Bosch MMB2000 Work Top Blender
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
Tighten these four screws and everything will be fine!
Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
Grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Blenders Logo
122 people viewed this question
Top Breville Blenders Experts
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
