Question about Home
Why won't my Cuisinart pressure cooker build pressure. Only used it 3 times
DOES NOT BUILD PRESSURE
emissionwiz
  • 78267 Answers
SOURCE: FUEL PRESSURE DROPS WHEN PUMP STOPS.HARD TO START
The fuel pressure check valve in the electric fuel pump has failed, you will have to replace the fuel pump, it is in the gas tank, also replace the filter at the same time or the warranty on the new pump will be voided.
Posted on Nov 04, 2008
  • 1388 Answers
SOURCE: WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Posted on Nov 27, 2008
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
SOURCE: compressor will not build pressure
Posted on Feb 28, 2009
RCtech
  • 55 Answers
SOURCE: wont build air pressure
Your problem falls into one of two categories the first is the tank is leaking the second is the compressor is leaking. Try this run the compressor for a minute or two and turn it off if to hear a hiss the tapers off slowly your tank is leaking some were check the drain on the bottom of the tank, the pressure relief valve on the top or side of the tank and all other connections between the compressor and tank.
In the event there is no hiss this means the problem is the compressor you may have a bad reed valve or a bad check valve depending on the type of compressor.
hope this helps
Posted on Mar 28, 2009
After pressure build keep warm
Either the recipe does not contain enough liquid, or it has thickeners that prevent the liquid from boiling.
Here is a trouble-shooter inforgraphic that should help you as well!
http://www.hippressurecooking.com/infographic-the-pressure-cooker-trouble-shooter/
Apr 23, 2014 | Cuisinart Electric Pressure Cooker CPC600
Steam release doesn't work
When the cooker is reaching pressure, the valve should point to the dot, and after pressure cooking, you turn the valve towards release. The valve will feel quite loose, but it if it's in the wrong position when the cooker is reaching pressure then the cooker cannot build, and consequently will not release, pressure.
Here is the manual if you need more information on how to operate the cooker:
http://www.hippressurecooking.com/t-fal-emeril-lagasse-electric-pressure-cooker-manual/
Feb 01, 2014 | Tefal Emeril by T-fal Electric Pressure...
Need manual for Cuisinart
The manual for the Cuisinart CPC-600 6-Qt (5.7L) Electric Pressure Cooker can be downloaded from the following link:
http://www.cuisinart.com/share/pdf/manuals/cpc-600.pdf
This is the commonly available manual for the Cuisinart pressure cooker. Do you have a different model? Can you provide the model number to enable a more detailed search?
Jun 10, 2012 | Cuisinart 6 qt. Pressure Cooker
Pressure cooker not building up pressure
Shanihulugal- please contact us at 1800-207-0806 x 127 or at: info@fagoramerica.com
We will replace the pressure cooker pot if the unit is defective.
Thank you.
May 31, 2012 | Fagor Duo Pressure Cooker 4qt
Lost instruction manual for Cuisinart cpc 600 require replacement!!!
The Instruction Booklet & Recipe for the Cuisinart Electric Pressure Cooker CPC600C series can be found online here:
http://www.cuisinart.ca/pdf/ibs/en/CPC-600C_en.pdf
Thank you for using FixYa!
Jul 11, 2011 | Cuisinart Electric Pressure Cooker CPC600
Still very new Tedelex pressure cooker: the red-headed pop-up valve seems to take for ever before "popping" and allowing steam pressure to build up. How long should I wait? Thanks, Nic
My pressure cooker does that too, you would have to wait until the steam starts to come out a lot, then it will pop out and start building up pressure. Hope this helps.
Apr 08, 2011 | Crock Pots & Slow Cookers
Cuisinart cpc600. What is causing erratic operation?
The recipe in it does not contain enough liquid, or the liquid is too thick, for it to reach and maintain pressure. Since the heat-up time to pressure is taking too long the cooker is shutting off.
Use tested, reliable recipes without condensed soups, flavor packets or jarred sauces. Don't worry, there are plenty!
http://www.hippressurecooking.com/pressure-cooker-recipes/
Dec 13, 2010 | Home
I have a Cook's Essentials Pressure cooker model #CEPC660. I have only used it a few times and I love it however it is not working properly. It is not building up pressure. I have checked the pressure...
sometimes it could be the seal around the lid, you might need a new one, the ring should be soft and movable not stiff and hard. the pressure leaks out before it has time to build up. hope this helps
Nov 28, 2017 | Home
Pressure cooker wont build pressure
you may need to replace the o-ring seal or replace the the pressure gauge
Oct 11, 2009 | Kitchen Appliances - Others
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
