I would like to try and flash stock firmware..but flash toolos wont recognice device
My samsung galaxy gt-i9003 mobiles imei is blank how do i recovery my imei plz help me
Hi Chanki, one question before posting my solution, did this happen after an update? Usually when update goes wrong, it deletes a folder or mess up a folder named EFS, here is the information for your imei among other info. If you have a little bit of knowledge on how to flash a firmware, then I recommend that you download Odin (a software for Windows which will allow you to flash firmware for Samsung devices) and a stock ROM (firmware) for you model. By flashing an original firmware, would replace and fix the missing EFS folder.
Mar 05, 2014 | Samsung Galaxy S GTI9000 Smartphone
Infocus in2114 firmware wont update
search on google plenty of fw availible but unknown if you can downgrade it without flashing back to stock
Nov 06, 2013 | InFocus IN2114
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
Jun 25, 2012 | ARNOVA 10 G2 8 GB PC Tablet with WiFi...
The garmin 265w is stock on a sreen and wont turn off
I can help you reset and fix your Garmin Nuvi 265WT.
Not starting, freezing, shutting down, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Nov 18, 2009 | Garmin n?vi 265WT Car GPS Receiver
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
Connect to PC and use device manager to repair
If you have the software conect the device to the computer; press volumen + with on/off switch at same time; then press volumen - anh hold it. The software recognice the device and you can update the firmware or repair it.
Aug 20, 2007 | Philips GoGear HDD6330 MP3 Player
32 people viewed this question
 Grubhead
Grubhead
