Question about Google Computers & Internet
Can the recovery console on a nextbook 8 p12 be repaired?..it says wrong volume...cant mount.
When i boot into recovery...it says...unable to mount recovery...bad argument.i downloaded firmwaare and flash too and drivers.ive tried every driver i could find...even google drivers.flash toolo will not recoognize devive
ThaMp3Doctor
  • 8596 Answers
SOURCE: Reinstall/Drivers
Go to:
www.usasupport.philips.com
Enter your model number
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "software and drivers"
Posted on Feb 11, 2008
proton77
  • 1183 Answers
SOURCE: Drivers won't install
Two possibilites here
1. the driver CD is corrupt , though belkin is a plug n play adapter, there is no need to install the cd
2. Since you getting an excalmation suggests , windows recoganises the new hardware but fails to install.
The best option is either change the manufacturer of the adapter or reinstall windows , it should fix your problem
Posted on Apr 06, 2008
yooperbud
  • 8637 Answers
SOURCE: Drivers will not install.
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
  • 76 Answers
SOURCE: unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Posted on Oct 08, 2009
SOURCE: Cant find a driver for my CenixVR P3490. Unable
How to erase recorded files on my cenix vr-p2170 voice recorder
Posted on Apr 24, 2011
How do you get a Nextbook tablet to stop freezing
Buy an Apple iPad!
Do a Factory Reset on it which reloads the operating system.
Power down. Hold the volume up button and the power button until you see the Recovery Console.
May 05, 2018 | Nextbook Tablets & eReaders
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
How can I factory reset a nextbook model NXW101QC232
To enter the Recovery mode (and reach the repair or reset options), with the tablet shut-down, press and hold the power and Vol - buttons. Both of these buttons are on the back near the top right. The power button is the right-most button. The volume - is on the left of the volume toggle and the toggle is adjacent to the power button. This is on page 14 of the manual. You can see the manual at ManualsLib here: https://www.manualslib.com/manual/1155142/Nextbook-Nxw101qc232.html?page=14#manual .
I hope this helps.
Mar 08, 2017 | Computers & Internet
My Nextbook ares 8 won't come on it just stays on the loading screen
Power down if you can. Press and Hold the Volume Up button and the Power Button until you see the recovery console. Choose Reboot or 'Soft Reset' if you can. If that doesn't work, you need a Hard Reset which scrubs the machine clean and reloads the Operating System. You will get the option to Back Up.
Jan 03, 2017 | Nextbook Tablets & eReaders
I forgot my password for my nextbook tablet. serial no.yfg0414022138.How do I log into my tablet or reboot it to factory settings?
Press and Hold the Volume Up and the Power Button until the Recovery Console appears. Choose Hard Reset.
Dec 14, 2016 | Nextbook Tablets & eReaders
NEXTBOOK 8 ,WITH WINDOWS 8.1, WENT INTO REPAIR LOOP, AND HOLDING POWER BUTTON AND VOLUME BUTTON WONT BRING UP MENU . NEED A FIX BAD
press power, press home button + volume at the same time a menu should appear in top corner , once that shows leave go of all three buttons then with volume press down and when you reach the heading you need press power . YOU DO THIS ONCE YOUR NEXTBOOK 8 IS TURN OFF ( make sure battery is in ).
Dec 23, 2015 | Nextbook Tablets & eReaders
I forgot password on my nextbook 8 quadcore how do i reset my tablet?
Hold down the power and volume up (or down). This will boot into recovery mode. Vol up or down will choose items, power will select.
Feb 12, 2015 | Nextbook Tablets & eReaders
How to unlock apps on nextbook
1. Back up everything you feel is important before you start.
2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
II. Necessary Downloads
1. SMT_Next8HD8G_Mod_Recovery.zip [Download link available in this post]
2. Kyser_Root-signed.zip [Download link available in this post]
III. Rooting the Nextbook 8
1. Extract SMT_Next8HD8G_Mod_Recovery.zip to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
2. Connect your device to your PC and copy both uImage_recovery and Kyser_Root-signed.zip to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
5. Once flashed, go back to the main menu and select 'reboot system.'
Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
Sep 29, 2014 | Tablets & eReaders
Error code Oxc0000185
Here is some info on fixing a corrupted UEFI Partition:
Firstly, boot from a Windows 8 recovery drive (CD/DVD/USB). If you don't have a recovery drive (and this is likely because most new machines don't come with one), then you will either have to install the drive into another Windows 8 machine or obtain a Windows 8 recovery drive, or boot from the recovery partition of the boot drive (If this option works at this point). Don't even bother with the automated recovery process, it will not work as it cannot find a Windows partition.
  1. You will need to choose the language and time settings.
  2. Choose 'Repair Your Computer'.
  3. Choose 'Troubleshooting'.
  4. Choose "Advanced Options'.
  5. Next choose 'Command Prompt'.
Next, we're going to use the DISKPART tool to verify that the UEFI partition has a drive letter assignment.
Enter 'DISKPART' (Enter)
(In this test case we removed all other drives except the boot HDD and DVD, so we know the disk 0 is our boot HDD)
DISKPART> sel disk 0
Disk 0 is now the selected disk.
DISKPART> list vol
There was no drive letter assignment to our UEFI partition (volume 3) so we need to assign a drive letter.
DISKPART> sel vol 3
Volume 3 is the selected volume.
1). If you know that you have a extra drive letter available use it here, otherwise skip to 2.
DISKPART> assign letter=E:
2). If you are unsure what the drive chain is or if you don't know what drive letters are avalable use:
DISKPART> assign
If all went well, DiskPart successfully assigned the drive letter or mount point. You can verify that a drive letter was assigned by "DISKPART> list vol" again.
Exit DiskPart tool (Enter EXIT)
Next, we need to change to the boot folder on the UEFI volume.
Change to the UEFI volume into the boot folder. Use drive E: here or whatever drive letter was assigned above.
cd /d E:\Boot\
Now we will need to enter three command lines to repair the BCD store.
For MBR drives: (Drives < 1TB)
  1. bootrec /fixboot
  2. bootrec /fixmbr
  3. bootrec /rebuildmbr
For GPT drives: (Drives > 1TB)
  1. bootrec /fixboot
  2. bootrec /rebuildbcd
That's it, if all went well the BCD store should be repaired, and the system will once again boot.
Jul 29, 2014 | Dell Inspiron 13z 5323 Core i5-3317U...
OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Nov 13, 2010 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
