Question about Electrical Supplies
Where is the spark plug on the green works generator
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Trace the spark plug wire.
Posted on Sep 23, 2017
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Cannon penncraft cannon work
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 12, 2014 | Electrical Supplies
Allpower American. 10000w generator won't start? Changed spark plug, gas is flowing. What else can we try?
Make sure it has plenty of oil. Some engines have a low oil shut off. Pull the spark plug wire off and stick a screw driver down inside the spark plug boot and hold the screw driver about a 1/4 inch away from the top of the spark plug and turn the engine over to see if you have a good bluish spark. If you don't then you have a bad coil or rust build up on the flywheel. If you have spark make sure your gas tank is full with new gas. Make sure the air filter is clean. If that doesn't work try taking the bowl off of the bottom of the carburetor and verify gas flows through the float valve. If that doesn't work then you will probably have to remove the carburetor and clean it out.
Feb 15, 2014 | All-Power America All Power 10000w Apg3090...
I have a 1996 lance camper with a 2500 onan generater lp cant get the spark plug out can you help
Spray the plug base with a good penetrant and give it time to seep into the threads and work.
Failing that you can sometimes carefully heat the head around the plug with a small hand torch and get the head to expand enough to enable you to break the spark plug loose.
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
I have a yamaha generator and it will not start/electric start or pull also will not start
If it was left unused for a few months with fuel in it the fuel forms a gel in the carburettor and may have blocked jets. Try the solution below:
First to check that the plug is sparking;
  • Remove the spark-plug
  • Push it into the HT lead, the lead that normally is pressed onto the top of the plug, and rest it with the metal part of the plug against the metal of the generator
  • Pull the start cord and see if the plug sparks.
If it does the problem is with the fuel. If it doesn't try replacing the plug.
  • Assuming that the plug sparks alright pour about 5ml, 1 teaspoon, of fuel into the opening where you took the spark-plug out of.
  • Dip the end of the spark-plug in fuel so the spark gap is wet and replace the plug in the generator.
  • Try starting the generator
The fuel you poured into the spark-plug opening should burn causing the generator to start. The procedure may have to be repeated 2 to 3 times.
If there was fuel left for a few months in the generator and it has formed gel in the carburettor this procedure may not work. If this happens the only solution is to have the carburettor stripped down and the jets cleaned by a mechanic.
Dec 19, 2010 | Sport & Outdoor - Others
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Hi! there anybody help my power generator won't powering on i even replace the spark plug but to no avail i mean no luck I've try so many times to pull the string for starting up but no luck and even reset...
Take the spark plug out, connect it back to the wire, and rest it so it is touching metal, Pull the cord and see if you see a spark. If you see a spark that means you are not getting gas. Put a few drops in the hole and replace the spark plug. Pull the cord with the choke off a couple of times and it should fire up briefly. If this is the case you will have to clean out the bowl and gas supply lines.
Mar 14, 2010 | Electrical Supplies
No spark on spark plug how to check ignator coil and pulse generator
To check the ignition coil, unplug the wires going to it and check the resistance with an ohm meter. There are two parts of it to check, the primary and secondary circuits. The primary circuit is the low voltage side where the black and green wires from the harness attach. The resistance through this part of the coil should be between 0.16 and 0.19 ohms. Check the secondary side by measuring the resistance between the spark plug lead and the primary side where the green wire was attached. The resistance there should be between 3.69 and 4.51 ohms.
The resistance through the pulse generator, as measured between the two wires that come from it, should be between 468 and 572 ohms.
Generally, the various components of the ignition system are very trouble free. If you're not getting spark to the spark plug, be sure to check all of the bike's wire harness and connectors for corrosion, melted connectors, broken wires, etc.
Nov 22, 2009 | 2003 Honda XR 650 L
Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Mar 11, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Electrical Supplies Logo
110 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
