Question about The Watches
May husband's Neo Abyss Watch needs a new stem. Where do I send it to get it replaced and what would be the cost?
5 Suggested Answers
SOURCE: broken date adjusting stem
We do that kind of work. just send it in. www.finewatchmaking.com
Posted on Aug 30, 2007
  • 93 Answers
SOURCE: My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have a majestron pocket
I went to Fossil's website, and didn't see a way to contact them for repair. If you still have the manual that came with the watch, it should have a contact number for support.
If you have any success with that, take it to a reputable watchmaker/repair person, and they should be able to help you (call around to find one first).
Good luck, and hope this helps.
Posted on Dec 08, 2010
  • 39415 Answers
SOURCE: Does anyone know how to take crown and stem out of my Michael kors watch model#8108
Take your watch to a jeweler for replacement of the crown and stem.
Posted on Mar 04, 2017
Mar 04, 2017 | Crown Watches
How much
The Abyss 10.900 is a waterproof diving watch that features a silicone filled stainless steel case and stainless steel unidirectional bezel on a black rubber strap. Silicone is denser than salt water, making the Abyss water resistant to grater depths. 10.900 is the depth in meters of the deepest location on earth, the Marina trench in the Pacific Ocean. The refractive index of silicone enables you to see the dial and hands from any angle under water. You can typically buy this watch for about $425.00
Jul 17, 2011 | TechnoMarine Abyss ABS01 Watch
The time set(wind pin) came out of my watch and i was woundering how much the part is. also how unique are these pins from one watch to another?
The only way to know the exact amount a new stem (wind pin) is, is to find out the type of movement that is in your watch. Typically, my husband would charge the jewelry store, $10-15.00 to replace the stem, in turn the jewelry store will double that, to make their profit. These pins are unique to the type of movement you have. hope this helps!
Jul 17, 2011 | Croton "Chronomaster" , cc311096bsmp Watch...
I went to put a new battery in a LACOSTE model or part number 2000308 ladies leather strap watch only to find that there was no movement at all ???? what movement and spacer if any do I need
A watch with no movement in it is probably a salesman's sample or display model. These are often distributed to stores as part of a larger display. In addition to missing a movement, you should also check to see whether the hands have been glued in place. This is also often done because, without a movement, the hands would just flop around instead of staying in an attractive position.
Watch movements come in a variety of standard sizes and shapes. However, a standard ladies watch movement (made by many manufacturers) would probably fit your watch case. This size movement is today used in much larger watches, too; the movement is simply anchored by an appropriate spacer.
A jeweler advertising watch repair should be able to offer you a price on this job. If the hands have been glued to the dial, it may not be worth "upgrading" the watch because of the additional expense and potential damage to the watch face from getting the hands freed up.
If you're ambitious and want to try it yourself, movements can be found online at a variety of watch supply houses like Otto Frei. You can also buy a cheap new or used watch at a flea market or thrift store and use the movement from that. You might be able to re-purpose the spacer in that watch, too, by trimming it to fit your watch case. The major stumbling point here is that watch stems--i.e., the stem on which the setting crown is located--are usually custom-cut in length to match a specific case, and the one you select may be too long or too short for your case. A watch repair place should be able to replace the stem and crown for you, if you need that service. Trimming an overly-long stem is a very simple and cheap procedure; replacing the stem requires a new stem, which will add to the cost of the repair.
May 09, 2011 | Lacoste 2000308 Watches Watch for Women
My husband bought me a elgin watch from walmart for christmas. I put it on and pulled the stem to set the time and when I pushed stem back in nothing happened. I also noticed that some of the...
Walmart has an over the counter replacement policy for up to one year. I would demand to see the manager because they are responsible for making things right, the last thing they want is a customer openly complaining about their products and exposing the general public to the bad service they have provided you, where this could have been taken of with an exchange.
Mar 23, 2011 | Elgin Watches
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
I Have a problem with my Technomarine ABS05. There is changed a battery by someone. but the watch doesnt work. I removed the back and some oil came out. where can i find that sort of oil? How can I change...
Oil should not come out of a watch. There just isn't that much oil in a watch to have it dripping out.
Are you sure it wasn't water? I can see where moisture could have gotten inside the watch if it was not sealed properly after the battery change.
The fast mall battery change places, jewelers and mart stores do not hire people that are trained to change batteries properly. We have a love hate relationship with those places. We love them because they keep us in business with all the watches they damage. We hate that they are in the business of replacing batteries in the first place because of how many watches they damage.
If you had one of those cheap battery stores replace the battery most likely they did not reseal your watch and it got water inside. This water will cause the problems you have now with your watch.
You will need to have a qualified watchmaker repair your watch.
Hope this helps,
Ken
Apr 16, 2010 | TechnoMarine Abyss ABS05 Watch for Men
Repair location in my area
Try AWCI.com for someone in your area. I recommend a good watchmaker even for a cell replacement, they will usually clean the case and band, do a consumption check, a min run voltage test and a water resistance test and new seals to keep watch fresh.
Jun 13, 2009 | Wittnauer Laureate 12R12 Wrist Watch
Broken date adjusting stem
Aug 29, 2007 | Polar (Ir) Infrared Kit (Serial Port)
Watches Logo
20 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
