Question about Samsung Office Equipment & Supplies
Samsung refrigerator RS285TDWP
Error code 5
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
Samsung frig RS265TDRS lashing error code S E or 5 E after power outage.
If you wish to get some details about refrigerator troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator"... http://electro-medical.blogspot.com/
Jan 22, 2017 | Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Samsung error code 5 C
Error Codes Messages Blinking
Error code 5 is for ice maker. Not sure about the 'C' part, though
if you go to this page also there will be a pop-up asking if you need help.
Aug 13, 2015 | Samsung RF4287HA
SAMSUNG REFRIGERATOR SHOWING CODE IE . POWER WENT OUT TODAY. HOW DO WE RESET IT?
Unplug the refrigerator for 5 minutes and plug it back. Now press "Energy Saver" and "Lighting" together and hold it for 3 seconds. It should clear the error message. Good luck!
Aug 24, 2014 | Samsung RF4287HARS French Door...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
Samsung Refrigerator Error Code 1E or IE
1E error is bad freezer sensor. You would need to either replace PART NUMBER: DA32-10104N behind the freezer evaporator cover or the main pcb PART NUMBER: DA41-00684A
Mar 15, 2013 | Samsung RF4287HARS French Door...
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
