Question about Bosch Ovens
Hi I have a Bosch double wall oven and the only thing it does is beep once when the breaker is turned on. I have bought both curcuit boards, the display panel and the touch pad and still nothing. The model number is HBL8651UC/01. Can anyone give me any idea as to what's wrong. I tested most of the wires and checked my voltage coming to the big circuit board. Please help.
  • 25 Answers
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
Posted on Dec 12, 2007
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
here is a link to the diagram.
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
SOURCE: Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Posted on Jan 15, 2010
  • 1711 Answers
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Posted on Aug 20, 2011
A F04 Err is flashing on my Bosch double oven. Please can you tell me what this means?
The only F04 error on a Bosch oven is with the Bosch 5000 Series wall oven. On this model, the problem is with the door latch. Unplug (or turn off at the circuit breaker) the oven. Turn it back on after a few seconds. When the power comes on, the oven should do a self-test of the lock mechanism. If the error persists, you'll need to do some diagnostics to determine if the lock is faulty. The problem could also be with the wiring or the control board didn't register the correct signal from the lock sensor.
Please add a comment with the model number of the wall oven for more assistance and any possible parts lists. You may want to call for service if you aren't comfortable doing this work. You probably need to get the oven out of the wall cavity for some of the diagnostics.
I hope this helps.
Feb 24, 2017 | Bosch Ovens
Oven is two weeks old. Town had a power outage we reset at breaker but still just beeps once and nothing happens
power outages cause power surges when the power comes back on
this surge generally manages to fry the power/control board
I suggest that you get the services of the service centre to come out and check it out.
May 30, 2015 | Bosch 27" Double Wall Oven HBN56
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Was cleaning oven other night...wouldn't unlock when done...beeping f-3 f-2...trying to cook now in oven and it just keeps shutting off and beeping out of the blue f-3 f-2 again...cake in oven...HELP...
The only thing that I can suggest to you is to locate the breaker for the stove in the breaker box and turn off the power. Leave the power off for at least a minute. This will reset the oven to factory defaults.
Once you turn your breaker back on you should be able to open the oven.
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
Aug 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Ovens Logo
50 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
