Question about Cell Phones
I have a 3810 Tr. with three position switch on top left corner. which can be used for flap controli.e half or full flap. My Tr. manual does not feature this switch setup. Can I purchase a new manual with this function detailed.
    President:
  • 2,777 Answers
I can definitely provide this for you, please confirm the make and full model of the device. You have this listed under cellular phones, is this definitely a cell phone you are talking about? I am certain I can help you here, just please give me the full manufacturer name and model number information on this device.
I will be watching for your reply, please do not put that I was not helpful / didn't answer the question until I get a chance to respond back to you again.
Thanks!
Tim
Posted on Jul 27, 2009
I cant move the jandy valve for pool return which means I can't turn filter on because if I do pool drains into spa.
Have you tried using the three way toggle switch on the JVA? It might be in the locked position.
If the JVA is not working you can always move the valve manually until you replace it.
First, put the directional toggle switch in the locked (center) position.
Second, loosen the retaining screw on top of the JVA handle about half way to three quarter out.
Third, push down on retaining screw firmly to disengage JVA.
Fourth, while pushing firmly on retaining screw rotate valve manually with handle to desired position.
Jul 03, 2017 | Jandy Pool & Spa
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
Where is the neutral safety switch located on 1998 ford crown victoria
On 1992 and later models, the neutral safety switch is incorporated into the Manual Lever Position or Transmission Range MLP/TR sensor.
RENOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely on jackstands.
  3. Place the transmission in Neutral.
  4. Remove and discard the manual control lever nut, then remove the lever from the transmission.
  5. Detach the TR sensor electrical harness connector, remove the TR sensor retaining bolts, then pull the TR sensor off of the transmission case.
To install:
  1. Position the TR sensor against the transmission case and loosely install the 2 retaining screws.
  2. Attach the TR sensor electrical harness connector.
  3. Use an alignment tool, such as the TR Sensor Alignment Tool T93P-70010-A, to align the TR sensor slots.
  4. Tighten the TR sensor bolts to 80-100 inch lbs. (9-11 Nm).
  5. Position the manual control lever onto the TR sensor, then install the new lever nut to 22-26 ft. lbs. (30-35 Nm).
  6. Lower the vehicle.
  7. Connect the negative battery cable.
ADJUSTMENT
Fig. : Adjusting the MLP sensor (click image for zoom)
Park is the last detent when the manual control lever is full forward. Return 2 detents toward the output shaft for Neutral.
  1. Position the manual control lever in Neutral .
  2. Raise the and safely support the vehicle.
  3. Loosen the sensor retaining bolts.
  4. Insert Gear Position Sensor Adjuster tool T93P-700 10-A or equivalent, into the slots.
  5. Align all 3 slots on the MLP sensor with 3 tabs on the tool.
  6. Tighten the attaching screws to 80-100 inch lbs. (9-11 Nm).
  7. Lower the vehicle.
Hope this helps (remember to rating ans leave a testimonial commnet about this free answer).
Oct 11, 2011 | 1998 Ford Crown Victoria
Need installation instructions to replace SW-6538, range sensor, for 2005 ford focus
only have 2002 right now
SECTION 307-01: Automatic Transmission/Transaxle 2002 Focus Workshop Manual
IN-VEHICLE REPAIR Transmission Range (TR) Sensor Removal
  1. Disconnect the transmission range (TR) sensor electrical connector and the selector lever cable.
  1. NOTE: Failure to hold the shift lever while loosening or tightening the manual shaft lever will transmit rotational torque to the TR switch and shift mechanism.
    Remove the TR sensor (automatic transaxle removed shown).
    1. Remove the manual control lever.
    1. Remove the bolts.
Installation
    Install the TR sensor (automatic transaxle removed shown).
    • Loosely install the bolts.
    • Install the manual control lever.
  1. Using the special tool, align the TR sensor and tighten the bolts.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use air tools on this bolt. Hold the manual control lever while tightening the manual control lever bolt, failure to the manual control lever shaft could occur.
  1. s2y~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Check the manual control lever is in position "3" same as "D" position.
    Adjust the manual control lever to TR sensor "D" position.
    1. "1" Low 1
    1. "2" Low 2
    1. "D" Drive
    1. "N" Neutral
    1. "R" Reverse
    1. "P" Park
    • When in position "D" the marks on the manual control lever line up with the marks on the TR Sensor.
  1. Connect the selector lever cable and the TR sensor electrical connector.
May 23, 2011 | Ford Focus Cars & Trucks
I left top half way up while cleaning rear galass. now top will not go down. got trunk working & roll bars go up and down. when i unlatch the top i hear nothing. normally you can tell the top is...
first try with disconnect battery ground cable, disconnect cable an leave 2 minute then fix it back and have a look, if not work now it's position uneven, you must close the roof slowly by hand up to locking position after that first operate the switch for closing and let it lock properly then till lock the boot lid to the right position with two flaps then switch off ignition let it stay 5 minute without doing any thing and, after that open the roof, if not work in this way you must fix Mercedes diagnose tool in to the car for manual activation through diagnose tool, and also would like to ask you to check the boot separation flap again is it in the right position if it not close properly it won't work,
Nov 15, 2010 | Mercedes-Benz CLK-Class Cars & Trucks
How tor resync convertible top button switch flashes
The soft top control module should reset every time the ignition switch is off and the key is pulled out. There are two types of flashes. If the switch flashes fast it means the luggage cover in the trunk is not in place. If the light flashes slow it means there is an electrical problem. Meaning the control module is not seeing one of the micro-switches in the correct position. You can try manually opening and closing the soft top by locating the pressure relief screw in the back of the trunk. There will be a little flap of carpet towards the left center. Use a flat blade screwdriver to turn the bleeder screw to the left. This allows the hydraulic fluid to bypass the pump so that the top can be moved manually. You will need a 5mm allen to unlock/lock the latches.. Double check in the owners manual there might be illustrations I can't remember for sure if it does or doesn't.
Oct 01, 2010 | 2001 Mercedes-Benz CLK-Class
Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Apr 14, 2009 | Fellowes PS60C-2 Shredder
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
