Question about Building Materials
When I pushed the button in my 2008 Saturn Vue to close my garage door, the buttons recessed behind the access panel. How do I open the access panel to fix the buttons?
SOURCE: My garage door will not close unless...
Check your down limit switch and even your up one too almost sounds like one is stuck one way or the other.
Posted on Jun 19, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 3197 Answers
SOURCE: Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Posted on Apr 12, 2010
swolfinor
  • 504 Answers
SOURCE: garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Posted on May 24, 2010
  • 3197 Answers
SOURCE: My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Posted on Feb 22, 2012
Where is the fuel door release button on a 2009 Saturn Vue?
There is no fuel door release button in 2009 Saturn Vue. When the vehicle is locked the fuel door is also locked. You can only open the fuel door by pulling it from outside when the vehicle is unlocked.
Dec 29, 2017 | Saturn Cars & Trucks
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
My saturn vue 2008 hatch i add open & in locked mode, it xoes not respond to key ?
GM usually puts a mechanical release for there electric doors, but it seems they did not for that model. And the door panel is impossible to remove without destroying it in the process. BUT you can pull it loose in the middle and gain access (very carefully) without breaking the panel.
I suggest seeking some one that has experience in this matter to solve the issue, as inexperience may cause your rear panel to be broken appart.
Jun 17, 2014 | 2008 Saturn VUE
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dome light comes on by itself long after door is closed
On the 01 Lincoln it has something to do with the keyless pad on the door press and hold button 9-0 till the green light around it goes out!
Jan 14, 2009 | 2001 Lincoln Continental
Remotes wont close door
IF THE DOOR WORKS NORMALLY FROM THE WALL BUTTON AND YOU GET NO RESPONSE FROM THE REMOTES (NO CLICK ETC.) THE LOCK BUTTON HAS PROBABLY BEEN PUSHED.
SEE IF THE LED BEHIND THE BUTTON IS FLASHING IF IT IS THE VACATION LOCK HAS BEEN ACTIVATED - PUSH THE BUTTON MARKED LOCK AND ALL SHOULD BE WELL
HOPE THIS IS HELPFUL
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
112 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
