My portable air conditioner lp1010snr has a pH or pass a P2 flashing in the screen hold the drain plug in back very little water in it I don't know where the reset button is, what else do I do
  • Heating & Co... Master
  • 1,875 Answers
It's with the water. Drain the bucket, vacuum the tubing. If problem persist it's possibly a bad sensor
Posted on Aug 11, 2017
3 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Posted on Apr 18, 2012
sodeep
  • 3267 Answers
SOURCE: how do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
Testimonial: "I did that and let it run for a few minutes and it did work. It's been cool out ever since so when I give a full days worth I'll let you know how it works out. Thanks. :)"
My portable ac unit keeps filling with water and shutting off. Why is it shutting down once an hour and flashing p2?
if it's a window unit it needs to sit at an angle so the water can drain out of the back. Make sure the drain is unclogged
Jul 16, 2012 | Heating & Cooling
Apr 17, 2012 | LG Heating & Cooling
How do you drain water from a LP1010snr air conditioner?
Apr 17, 2012 | Heating & Cooling
Hi I HAVE A DIMPLEX AIR-CON It was already here when I moved into this house but lately after it been for on about 5 mins it stops and it display a code of P2. I dont know how to get hold of a manual...
If your model is a portable AC unit, the P2 indicates that water needs to be drained from the tank.
Turn the unit OFF and unplug it, before draining the water from the lower tank into a shallow sided pan capable of holding at least 1 quart of water. Once it has completely drained, reinsert the drain plug, plug the unit in and turn it ON. The P2 Error Code should have disappeared. If not, press the ON/OFF button twice.
I hope this helped you.
Jul 15, 2011 | Heating & Cooling
We have the portable air condioner model LP1010snr and we have drained the tanks and still have the P2 warning. It will not start working. what can we do?
Turn the Master ON/Off Switch to OFF and unplug the unit for 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings.
Hope this helped you solve the problem.
Jul 09, 2011 | LG Heating & Cooling
I purchased and LG Model# LP1010SNR on 8-3-10 at Home Depot. It was a floor model and did not come with an owners manual. It has a digital display screen. It is intended to run for several hours at a time...
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Aug 04, 2010 | LG Heating & Cooling
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Everstar MPM1-10CR-BB6
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Jun 17, 2008 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
