Question about Comfort Zone Heating & Cooling
I have a older comfort zone thermostat. It is flashing program and says heat?? We are trying to put the ac on??
  • 1,386 Answers
Change the system selector to cool. Press hold if applicable and then set desired set point.
Posted on Aug 11, 2017
Benimur
  • 6966 Answers
SOURCE: A thermostat versus an AC problem
"outside sensor error" is indicative of a Diagnostic error display, a feature where the device checks the functionality of each attached component. It would seem that your system has the optional "Outdoor Temperature Sensor" (probably P/N TSTATXXSEN01-B). The error then indicates that either that sensor is faulty or the hook up cable is unplug or defective. If you do not observed any critical changes in the comfort inside your home or the area that your system monitors/controls, then this only confirms that it is external and a sensor problem and does not affect the A/C and/or the variable speed furnace/comfort zone system. Normal faults could be the external sensor to cable connector/terminals being exposed to the elements and would require hard cleaning.
This sensor is not critical to the operation of the system and is optional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
james3751
  • 614 Answers
SOURCE: The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Posted on Mar 25, 2010
  • 22 Answers
SOURCE: Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Posted on May 06, 2010
My comfort zone 2 thermostat and unit is brand new. I have 2 zones. AC works fine in both zones but when I needed heat only zone 1 heats which is downstairs. Zone 2 which is upstairs, does not heat.
I would call out the installer, you said it was new, so it should be under warranty.
The "W" wire is traditionally the call for heat which may not be getting to the upstairs unit, and if it is, then the unit needs to be diagnosed.
Jan 23, 2016 | Heating & Cooling
Is there any process needed to implement for the summer to winter thermostat settings
You didn't mention what thermostat(s) you have but most simply require you to go from cool to heat and then check the temp setting(s0 to make sure they are in your comfort zone.
Nov 13, 2014 | Rheem Classic Series 95% Two-Stage Upflow...
Simple comfort thermostat
make sure stat is in heat mode if it only heats in cool mode then wrong wires were hooked up to furnace also try pressing the hold button and see if that gets you anywhere
Mar 31, 2014 | Heating & Cooling
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Thermostat issue with comfort zone II.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Heating & Cooling Logo
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
