Question about Intex Pool & Spa
Water leaking out of an intex pool filter - Intex Pool & Spa
  • 13 Answers
SOURCE: I have a 24 x 52 intex above ground swimming pool
You must open the little valve on top to let out the air, then screw it back on when water reaches the top,  and ensure both gates are open.
Posted on Mar 30, 2009
SOURCE: the pump/filter combo for my easy set pool doesnt
There is an air/suction leak on the inlet side of the pump or, if this is an above ground pool, the pump is not set below the level of the pool.
Posted on May 31, 2009
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
  • 3 Answers
SOURCE: I keep getting code 90 (low water flow) on my
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Posted on Jul 08, 2010
SOURCE: Hi- I'm a new intex above ground metal frame pool
how do I hook up my 1000 GPH intex filter pump?
Posted on Jul 18, 2010
The pump is running but not pumping much water even though the filter is clean
It sounds like your connections in your pool filters might not be tight or you might have a leak. Check your entire pump and filter to make sure that there are no leaks or loose connections.
Aug 03, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My rubber seal that fits over the filter lid tore in half, I guess my water is hard and sun deterioated it need to find replacement so water doesn't all leak out.
these o rings are model specific. you need to go to your local intex dealer with the model number, and they can supply. use a silicon based lubricant on the new ring, that will help preserve it. good luck!
Jun 14, 2010 | Intex Krystal Clear Model 635 Pool Filter...
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I had boughten a intex pool from a garage sale and the pool is fine but the filter is leaking water everywhere and all the water that is in the pool keeps coming out.
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at
call them up and order your parts
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I cannot get one of the filter valves closed
Water should not be draining from your pool filter at all. There should be one hose that connects to from the filter to the pool and another hose that returns the filtered water from the filter to the pool. It is a continuous loop. If water is coming out of your pool during this process, either you don't have a hose connected properly or the hose is leaking/cracked.
Jun 16, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Pool & Spa Logo
Top Intex Pool & Spa Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
