Question about Jandy Pool & Spa
I have an invalid command on jandy lite 2 heater .any help with a fix
    Top Expert:
  • Jandy Master
  • 7,361 Answers
Is it connected to a controller if not take off remote and put on manual
Posted on Sep 05, 2017
  • 10 Answers
SOURCE: jandy lite 2 LG250N ..heater will not come on.
you may have a lose conection or may be dirty check your conections look for burns or frays in the wireing
Posted on Jul 10, 2009
  • 246 Answers
SOURCE: I have a 10 year old Jandy RS4 controller which is
must replace water tem sensor
Posted on Aug 25, 2009
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
  • 1378 Answers
SOURCE: Jandy Lite 2 pool heater
Thank you for posting your question here on
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at Positive feedback is appreciated once your problem is solved!
Posted on Apr 29, 2011
SOURCE: Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Posted on Jun 14, 2011
Jandy lx 250 invalid command message
is unit on a controller if so take off remote
Jul 06, 2013 | Jandy Laars Lx 250,000 Btu Heater
Insulation gone in Jandy Lite 2
need new heater that one is unsafe
Jun 02, 2013 | Jandy Pool & Spa
The display lites up a fl0 which means a saftey control board. how much does one of those cost. i have a jandy lite 2
You might contact Jandy technical support number at 800-822-7933. They might be able to answer some of your questions. I hope this helps.
Aug 16, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 pool heater
replace ignitor and make sure fuses ok
May 30, 2010 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
Jandy Lite 2 LG Model not firing up. Was working during day
ok 24 v at the transformer is yes than a safety swicth turn the heater off check fuses
Jul 10, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
Feb 15, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool & Spa Logo
82 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
