Question about JVC Car Audio & Video
I have a car that my brother gave me for my birthday and it has an jvc stereo in it I think it is in demo mode and I have no manual to set it up
Cerfer39
  • 709 Answers
SOURCE: jvc kd-g116 car stereo manual
here are a couple of manuals that might be right for your Radio.
http://books.jvcservice.com/booklist.asp?Model=KD-G110J
http://books.jvcservice.com/booklist.asp?Model=KD-G120J
Posted on Nov 07, 2007
SOURCE: Setting the clock
I found the solution to this:
With the ignition turned on use the source button to shut off the stereo. Press and hold the function button (in the upper right corner) for 2 seconds. The front panel will light up. Press the funtion button to get the display to cycle through the different options. When it displays the time, use the up and down and left and right keys, located just to the left of the funtion button to adjust the hours and minutes.
Posted on Jan 20, 2008
SOURCE: JVC KD-G322 Demo mode
Hold down the "SEL" button, and use the CD track skip button to scroll to where the display says "DEMO," and use the volume knob to change the setting to "OFF." Push SEL again and you're good to go.
Posted on May 13, 2008
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
SOURCE: How to disable demo mode on JVC MX-c220
Make sure the unit is on. Press the FM Mode /Mute -Demo button (right next to the power) press it untill you get to either mono or auto (-for stereo). That will take the unit out of the demo mode. next turn the music jog dial (located just above the preset buttons) untill you get to which ever setting you choose. Hope that helps. ( I can't find the manual on line either- not even from JVC! )
Posted on Jun 10, 2009
How to set the color on my faceplate. It contnues to change color
You're stuck in DEMO mode. When you see stereo's on display at a store it is set to a DEMO mode that cycles through colors, functions, etc so that potential customers can see the different aspects of the unit. To get it to stop changing colors you'll have to go into the menu and turn DEMO OFF.
Aug 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do i permanently keep demo mode off on my JVC car cd player? Everytime I remove the fascia it resets the settings and the demo mode comes back on. The model I have is the KD-R711. Thanks
Hold down the menu button for about 2 seconds.
Will take you to menu mode, first option should be demo, if not scroll over to demo menu
by using the know. Push the knob in to enter the mode, then using the knob get to off display, push the know in once again to set it to off. After hit the menu button to get out of menu mode.
Jan 08, 2011 | JVC AM FM CD DET FACE CAR STEREO
Have a jvc car stereo and cant turn off demo mode
If you press and hold the menu button the display will change into the main menu mode. Scroll to "DEMO" and click or press in button. You can then scroll to On or Off effectively turning off or on the demo mode.
Aug 24, 2010 | Car Audio & Video
My car stereo player is on "demo" mode and i can not get it to turn off. i would like for it to display the name of the song/station but every few second it says "demo" and cycles through the different...
Hold SEL
use right/left buttons to select DEMO
turn dial to select DEMO OFF
owner's manual here:
http://resources.jvc.com/Resources/00/00/91/GET0467-001A.pdf
Jun 21, 2010 | JVC KD-PDR30 CD Player
How do I stop the JVC from wasting the readout on KM200?
Hello mwalkercom
It sounds like your JVC is still set for factory default which is "DEMO" mode.
To cancel the DEMO, you need to go into PSM (personal settings mode).
1) Press and hold SEL until the display changes.
2) Press left/right rocker until DEMO is displayed.
3) Turn volume knob to change to DEMO OFF.
4) Press SEL briefly to exit.
Now you can use the DISP button to change the display to show the options you desire.
Hope this helps.
Aug 31, 2009 | JVC AM FM CD DET FACE CAR STEREO
How do you turn off the demo on the jvc car radio
Hello gusjandreau,
Press and hold the SEL button until the receiver enters the PSM mode (until the display changes). Use the left/right rocker switch until the display reads DEMO. Turn the volume knob until display reads DEMO OFF. Briefly press SEL to exit PSM mode.
Hope this helps.
Jul 22, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
Mar 09, 2009 | Audio Players & Recorders
Can't set time on jvc kd-s14 car stereo
Press and hold select button on front of receiver
Use left and right control know (the one you would use to forward or reverse a track with the cd)
This will carry you into some more settings, including the hour and minute access
Use the volume knob to rotate to desired hour
Jan 29, 2009 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
Dec 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
29 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
