Question about Vacuums
Can i parches a new holder for my N207 as the suction Lets go
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
I have an upright bissell pro heat self propelled. I have had it for years and it has always worked wonderfully. Last time I was using it water started going everywhere. The self propel part is only...
If the top portion of the upright section is loose, there is a connector between the two parts that is also loose. No need to take it apart however beyond removing the black lower hose holder.
To remove the lower hose holder, just push in firmly on the tab that is the same color as the upright casing until you can pop the lower holder upward and off of the machine. Beneath the holder are four screw holes where you can tighten the upper and lower assemblies back together. This will reconnect the two connectors internally and take care of any power issue to the base.
Apr 02, 2011 | Bissell 1699 ProHeat Clear View Upright...
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
Beater bar not working. suction not working
Check for a broken beater brush belt. Clean the beater brush, clear of all debris and add some WD40 at each end where the rubber holders are. Turn beater brush by hand to work the WD40 into the axle. Reassemble making sure the belt is on correctly. This should also help solve the suction problem as well.
Oct 01, 2010 | Dyson DC07 All Floors Bagless Upright...
I vacuum seems not to have any suction; for a while the attachment had suction; now it does not.
If you have checked for the obvious clogs and obstructions, be sure the belt is working properly and if necessary, attach a new belt to the unit. At the same time, clean the beater brush and lubricate the ends between the brush and the hard rubber holders.
I would also check the hose for any potential leakage.
Paul
Sep 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Lack of suction
Do not think its motor .......Yoy need to see thats its not Cloged if so clean.......
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction when vacuuming, but suction is good when using hose
check for blockage from where the hose sets in its
holder to the roller brush. Also see if the brush is
turning, the belt maybe broken.
Tom
Oct 22, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Suction through hose but not base
mine did the same when new, i checked all as above then i noticed that i could twist the round peice that will unplug) (right behind the carpet-bare floor knob) and then i got suction at the base to be able to vacuum the floors, then i notice that there was a peice of plastic broken off that actually pushed a black latch down when either pushing the handle all the way up or down this lets the round piece i'm talking about swap over from base suction to handle suction! hope this helps and everyone can understand what i'm talking about! you have to look close to see where the 2" by 2" piece of plastic is missing!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Floormate not suctioning water back up
I love my floormate so muck that when my first one stopped vacuuming, I bought a new one - just figured it died. Then my new one worked well until one day, it suddenly stopped.
I discovered that the filter attachment holder (the clear plastic cover over the filter) has to click into place. I guess this might not be a problem for some, but I thought it just sat there over the filter. I finally pushed pretty hard (mostly in frustration at first) and it clicked into place. Now the suction works fine.
FWIW
Jul 11, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
