Question about Electrical Supplies
What do you do to the LRE 5500 to get electricity output . Motor will run. Add part what is answer.
3 Suggested Answers
  • 384 Answers
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Posted on Jul 01, 2009
  • 4 Answers
SOURCE: 5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Posted on Nov 25, 2009
Portable 5500 watt generator no ac output
maybe it needs new brushes. you've done everything else
Aug 25, 2017 | Electrical Supplies
Northstar 5500 watt generator lost power to outlets and is squealing loud at the generator side of unit, there is no switch for output
squealing either bearing,bushing or winding going or gone if bushings or bearings might be able to repair if not to damaged
Aug 29, 2016 | Northstar Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
My north star 5500 generator starts but does not put out any electricity through the plugs
Check the connections between the alternator (generator) and the regulator/output connectors.
Oct 13, 2014 | Northstar Generator 9 Hp, 5500 Watt,...
I have a lincoln power arc 4000 it sat for several years in my shop i tried to use it, the motor runs but it has no power output on the generator side or the welder side. I let it run for about 10 minutes...
Not sure what the problem is but I have similar unit and the engine died. If you are interested in selling the unit/engine please email me at m_ramkiss@hotmail.con. My mobile is 1-868-366-9505.
Thanks Mike
Feb 26, 2011 | Lincoln Electric POWER ARC 5500 HONDA
Need to know color code for 220VAC receptacle, so can wire up an output cord. Had no cord with the generator. Have LRE 5500 portable generator. Have new 4 prong plug.
Hello Arthur,
For 220vac, you will have 2 blacks or Red and Black (line). The white is neutral, green / bare is your ground.
If you look closely at the plug, the contacts for the line will have either black screws, or be labeled as L1 and L2. Neutral will have a white or silver screw, may be labeled as N, and the ground will be green or silver, labeled as Ground, Gnd, E, or Earth.
Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
Is it possible to manage Cisco 585 LRE CPE remotely? Is it possible to monitor a Cisco 585 LRE CPE with i.e. snmp? Is it possible to remotely configure speed and duplex on either of the 4 LAN Switchports?...
blank.gifIF-MIB (RFC 1573) support for CPE Ethernet ports (read-only)
blank.gifRMON-MIB (RFC 1757) support for CPE Ethernet ports (read only)
These are the remote management options availible on this device.
Oct 02, 2009 | Cisco 585 LRE CPE (CISCO585-LRE) 4x10/100...
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Electrical Supplies Logo
32 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
