Question about Jensen Audio Players & Recorders
My Jensen JTA 220 plays records too slow. Can & how do I fix that?
4 Suggested Answers
  • 11800 Answers
SOURCE: would like to know if
Yes, it can. Just connect the RCA LINE OUT from it to the Line IN from the pc with a cable like
http://www.amazon.com/Dayton-3-5RCA-12-3-5mm-Stereo-Cable/dp/B000F7P7EW
Then to pick up the sound just use any recording program you want. I use
http://www.roemersoftware.com/free-sound-recorder.html
Posted on Jul 28, 2011
  • 3 Answers
SOURCE: Just received my Jensen JTA-460
There is a speed selector directly under the needle arm.
Posted on Sep 19, 2011
igadgetgirl
  • 27 Answers
SOURCE: how can i fix my jta-460 from playing records slow
Check the RPM switch on the turntable is on the correct speed for the record you want to play. Otherwise it could be a belt problem internally.
Posted on Mar 11, 2012
How do I fix the speed of my Jensen JTA-460 turntable? I've tried numerous records that previously worked perfectly, but now the speed is too slow regardless of what album I try.
Could be the belt for the pulleys is stretched a little, or there is something making it slip, or the potentiometers were set incorrectly from the factory . It is normal to have one for each speed. It is unknown if you can access these from the bottom of the unit. Slippage is less likely to be caused by something oily, since it would alternate the speed faster and slower and yours seems to have worked then reached a constant slower speed. Do your 45's and 78's play ok? (yeah I know, does anyone have a lot of 78's on hand)
Your model does not have an outside pitch control to fine tune the speed faster or slower. Another Jensen model JTA-230 does. Entry level turntables such as yours are not speed accurate reliable. After reading reviews on your turntable, it's possible that the belt is the problem. If the slow speed problem had happened from the start, it would be safe to say that the speed wasn't calibrated correctly and you could have returned it and perhaps had better luck with another one but because it worked fine at the start and then now plays slower, it's either the belt or the potentiometer for the 33rpm speed has somehow changed.
May 23, 2017 | Jensen Audio Players & Recorders
Can my turntable be adjusted
Jody, the arm the needle is on, usually adjustable with a dial on the end that can lighten, or put more weight on needle to help it track better on records. Other then that, the belts normally are changed to address slow speed issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JTA 220 Instruction Manual Page 2
http://audio.manualsonline.com/manuals/mfg/jensen/jta220.html
How To Calibrate Your Turntable For the Best Possible Sound
How to Adjust Tracking Force
Apr 09, 2016 | Jensen Jta-220 3-speed Stereo Turntable...
Jensen JTA-460 will not power ON?
It may start when the tonearm is lifted. If not, the turntable may have failed
Dec 26, 2012 | Jensen JTA460 Turntable
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
I need it now jensen jt a 460 turn table manual
Tech Help call 1800 686 079 Mon -Fri 9am to 5pm I have a JTA 380 Manual ? similar spec's.
Mar 11, 2012 | Jensen JTA460 Turntable
How can i fix my jta-460 from playing records slow
Feb 13, 2012 | Jensen JTA460 Turntable
Would like to know if the jensen jta-450 can be connected directly to my computer, if so, how?
Jul 28, 2011 | Audiovox Jensen JTA450 Turntable
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
78 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
