Question about Simpson Washing Machines
How to remove/replace drum Simpson genesis top loader
Thankyou, problem solved
    Habit-Forming:
    Scholar:
  • Simpson Expert
  • 161 Answers
Which drum? Inner spin drum or outer plastic drum? Why do you want to remove/ replace it? Some decent details may help you get an answer.
Posted on Aug 17, 2017
SOURCE: I am trying to remove the inner drum
The top panel?? Remove the screws at the bottom front. Pull the front panel out from the bottom while releasing the clips on top. remove the screws in the corners under the front of the top panel and swing the top up.3bceb93.jpg
Posted on Jan 06, 2008
dauphine
  • 207 Answers
SOURCE: Simpson Ezi Loader 5.5kg 45S558E
I'd say that belt might be loose a bit so it slips under load. That would explain why the motor can rotate empty basket but not the loaded (heavy) basket.
Posted on Apr 20, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
dmftrucker
  • 1922 Answers
SOURCE: I want to know how to remove the inner drum on my
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Posted on Nov 19, 2009
SOURCE: where does the spring belt
the motor is spring loaded - move lift motor towrards the cabinet lining to the right. Put band around drum and pully at rear of motor then allow motor to move back onto band to cause the tension
Posted on Mar 01, 2011
Simpson Top Loader - drum seems to have come loose - banging off side of machine violently. Where are the clips to fix the drum secure again? Cannot find anything in manual
They don't have clips to secure the drum. The drum has to be able to move. It is suspended on 4 rods with springs, one on each corner. I would suggest that you need 4 new suspension rods fitted.
Sep 19, 2017 | Simpson Washing Machines
Simpson 550 top loader. How do I remove agitator and clean under the bowl
Pull top part of agitator off an there should be a locknut visible 10mm I think,remove locknut an agitator should come free,it may need a few light taps to release,pretty sure its the same as my 750...hope this helps an good luck.
Dec 27, 2016 | Simpson Washing Machines
Simpson front loader and it appears that a screw(not related to the machine) has lodged between the inner drum and outer drum. When you turn it over by hand you can hear it rattling
if you dont want to call an engineer out, take the back off the washer, then at the bottom of the drum you can remove the heating element, Dont worry about water coming out, you may then extract the screw by tilting the machine backwards and using a magnet
Dec 29, 2015 | Simpson Washing Machines
Simpson 9.5kg top loader shutting down
It has to be doing something?! If it is just shutting down it is because it is Not draining. So you need the drain pump replaced
Jan 19, 2014 | Washing Machines
Brake band for Simpson Genesis 505 heavy duty washing machine
www.searspartsdirect.com or www.applianceparts.com. If the brake is internal with the gearbox, chances are the only way to replace the brake is with a new/rebuilt gearcase.
May 10, 2012 | Simpson Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
