Question about Vizio Televison & Video
I have a 10 year old vizio tv that stopped working. It will not power on but the cord is good and I replaced the power board inside, but it still doesn't work. The screen stays black and the vizio logo under the sreen is lit up amber colored.
  • 13 Answers
SOURCE: Vizio TV 2006 vx32Lhdtv doesnt work.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
Testimonial: "If all things are equal than the solution is at hand. I thamk you!"
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
TODDAS
  • 431 Answers
SOURCE: Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Posted on Nov 24, 2011
  • 302 Answers
SOURCE: No power at all, vizio logo not lit,
Hi if nothing is coing up at all then you provably have a power supply issue.
You can get parts for this tv at www.interliquidparts.com
Posted on Mar 02, 2012
  • 4 Answers
SOURCE: My vizio E370VLE is getting no power at all. The vizio logo under the screen isn't even lit up. I have tried plugging into new outlets and even switch out the power cord with a new one so i know its n
the problem is probably your main power board.. these can be replaced by yourself.. find the model no and then enquire about a replacement board ..I have had similar problem tv repairman wanted $500+ to fix board only cost $134..make sure to disconnect power supply ..undo all the screws around back of case including wall mount and base follow power lead entry into case do not touch any circuitry as some capacitors store power disconnect the little plugs that run from the boardundo the 4 screws and replace with purchased replacement board and re assemble..
Posted on Dec 21, 2014
How do I fix my VIZIO TV?
Vizio TV Repair - Instructables
www.instructables.com/id/Vizio-TV-Repair/
InstructablesSo my Vizio TV was flashing on & off rapidly every time I switched it on. ... good way to get something to work, but it got things working until I had time to repair it.
Fix Power Problems In 5 Easy Steps: What To Do When ...
vizhdtv.com/fix-power-problems-in-5-easy-steps-what-to-do-when-your...
Aug 26, 2015 - Vizio TV power cord plugging into a power outlet. Do you know ... Powerproblems might require service or replacing parts inside the TV. Before ...
Dec 14, 2015 | Vizio E-Series E470I-A0 47" LED TV...
My vi 42 in led lcd vizio works great for like 30 mins to an hour then the picture disapears but the audio is still intact and playing whats the issue has anybody else had this issue the tv is less than a...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
or you have faulty t-con board..
Jun 19, 2012 | Vizio Televison & Video
Vizio vw26l
replacing the power supply board should solve the issue you can get the replacement power supply board from www.tvrepairworld.com
Jun 01, 2012 | Vizio VW26L 26 in. LCD TV
Hi, i am having problems with my TV since day
Hello sir Ibsen,
The first thing I suggest is to check the power cord and its connection if the light indicator on the front of TV won't turn on..Used multimeter or volt meter (range to AC) to measure the voltage..If no voltage,replace the power cord because the cord have internal wire break or open connection that can't visually check..
If the power cord is good,the possible problem is power supply board inside..
It cost $89.95 to this site http://www.shopjimmy.com/lg-6871qih001a-power-supply-unit.htm
But before you decided to replace the power supply board please try to reset or reconnect all connectors on all boards inside specially on power supply unit..
Also I remind you when the TV already open the warranty will void...
If you more queries and clarification please feel free to reply to this tread..
Hope this solution will be helpful..Thanks for using fixya marketplace and choosing my service..
Feb 21, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a VIZIO VO47LFHDTV10A that is less than 4 years old. Last week the screen went blank but the sound is OK. The sound is fine on all inputs but no picture. Another TV hooked up to the same power and...
Good day!!!!
If the reset is not work the problem could be the inverter board found inside the TV..
When you open the back cover of your TV by unscrewing it..After that the inverter board become visible.
This is the sample picture of inverter board:
After you replace that board your TV back to normal operation..
Hope it helps..
Nov 19, 2011 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Our 3 year old Vizio plasma TV just made a popping sound and the screen went blank, then about 30 seconds later, a horrible piercing buzz started and we had to unplug the TV to get it to stop...Any ideas?
It just happened to me on 4/7/10. My vizio p50hdm made a popped noise & did not turn on. I purchased the tv at costco on June 2005 w/amex card. I pulled my amex statements from 2005 then called costco with my member # and they found the transaction. If you purchased the tv before 4/2007 the item is grandfathered with the 100% customer garrantee. After 4/2007 the return policy changed to 90 day money back return 2 year warranty and you get an additional year if you purchase w/amex card for a total of 3 years. Be very nice to the Costco people even if they give you an attitude on the return of tv. I got a credit for $2200. I just purchased a samsung led tv 46 series6 back lit & internet. Amazing Technology. & I Love Costco
Mar 30, 2010 | Vizio L32 32 in. LCD HDTV
Vizio 32 no power
http://www.encompassparts.com/models/?VIZVW32LHDTV10A justmanuals.com
do some research, pick out a weekend, and then replace that power board! save yourself some $$$ but make sure you order the right part and know what you are doing before you start.
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 42 inch tv Power Not working
It's very easy to swap the entire power supply board. If it's out of warranty, what do you have to loose? You can purchase a new power supply board from Vance Baldwin. They are the ONLY parts supplier for Vizio. http://www.vancebaldwin.com/ Once you receive the new board, it's just plug and play. Crack the case (a series of small screws around the back perimeter) and remove the old power board and replace it with the new one. It's that easy!
Jul 27, 2007 | Vizio L32 32 in. LCD HDTV
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
