Question about Smeg Ovens
Hi,Thanks for your website. SA398x-5 Smeg Oven Fan Blade not turning although element on okay, actually red heat, but fan not turning. Is this the switch operated by the door hinge.
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
  • 146 Answers
SOURCE: smeg single fan oven
Before you change anything try the broiler circuit. If the broiler works then it could be an element if not then you could have a problem with the oven thermostat.
Posted on Dec 24, 2007
hongster
  • 6 Answers
SOURCE: Smeg SNZ91MFX1 Fan heating not working
It could be that the element around the fan (which is obscured by metal plate) has gone. Remove the metal plate in front of the fan, and test with a multimeter to see if a current gets through it...
Easy to order and replace yourself
Posted on Jan 24, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: SMEG DO4SS-5 double oven not heating up
    If the fan is running, then it is safe to say that the oven element has gone.
    Replace with a new one,(element that is).,
    Plz rate this solution.
    Thanks.
    Posted on Dec 15, 2008
    SMEG OVEN BRAND NEW WON'T HEAT
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Sep 08, 2012 | Smeg Ovens
    Smeg Oven
    Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
    Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
    Does not heat up fan turns on smeg scp 111 multifuncation ELECTRIC oven
    If this helped like us on Facebook please
    How to Video Tutorials on Domestic Appliances
    Sep 10, 2009 | Smeg Ovens
    It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
    If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
    To replace: Turn off power!!
    -Remove side racks from oven, then remove rear panel.
    -You should now see fan blade and fan element.
    -You need to remove oven from cavity, then remove rear outer panel.
    -You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
    Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
    Aug 10, 2009 | Smeg Ovens
    The light and fan works but no heat comes on in oven.
    If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
    Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
    Noisy fan in Smeg oven SA398X
    Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
    Apr 18, 2009 | GE JGRP17 Gas Single Oven
    Smeg oven ss336-5 not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
    Thanks.
    Dec 15, 2008 | Smeg Ovens
    Smeg oven
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    If this helped like us on facebook please
    Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
    Botom oven not working
    Hi
    The oven element is probably faulty, I assume the fan is still working.
    Nov 23, 2008 | Ovens
    Ovens Logo
    32 people viewed this question
    Top Smeg Ovens Experts
    ashburton
    Jason Harris
    Jason Harris
    Are you a Smeg Oven Expert? Answer questions, earn points and help others
