Hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
related solve Forgotten phone password issue links:
http://www.vipprogrammer.com/unlock-passcode-on-iphone-7-7-plus-crack-the-forgotten-screen-password-programmer-3638
hope can help you!
SOURCE: YM error 81003005/log-in ID, password invalid
I observed that this yahoo messenger comes with the network's (where you are connected at) firewall restrictions. There has got to be in between with your YM and the firewall. This problem is common when you belong to a proxy.
Secondly, if the firewall is the one not bugging you, it might be the DNS servers are causing the troubles. Sometimes, it seems the connection goes well only that DNS problems got in the way. This occurs rarely but if you can catch this problem, headache solve. The second solution discusses this.
Lastly, this has also got to do with the software part, that is the YM itself. As you can read in some of the comments below, other accounts work well and to some do not. If this is the case, then the connection (firewall) itself is not the problem but the software. Yahoo's advise is to update to its recent version of YM. Well, I did this but I was trapped with the same problem. My second solution works well for this kind of problem. Read on.
Solutions
[Solution #1]
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Here's an old version of Yahoo Messenger (8.1.0.419.exe) - [Download]
Hope these helps.
SOURCE: I have my tempory password but cannot log kp.org/password
how do i activate my temporary password
SOURCE: My mother's Apple computer won't
I see. If that is the case I would suggest that we need to hard reset it so that password will be refreshed and will no longer ask you to type in password the next time you use it.
1. Press the power button located in the upper right hand side of the keyboard, just above the eject button.
2. Continue to depress the button for 10 seconds. The computer will power off.
3. Press the power button again to turn your laptop back on.
Or other way to bypass the password.
A MacBook is a laptop computer manufactured by Apple Inc. and has proven
to be one of its all-time popular products. It is its
"bargained-priced" laptop, although it is generally priced higher than
comparably equipped Windows laptops. A MacBooks runs on the same
operating system software (OS X) as Apples desktop computers. MacBooks
(and other models of computers) can have several passwords, namely an
administrator password, which is required to install or update software,
and a password for every additional user account.
1. Determine how many administrator and user accounts are on the MacBook.
If the computer is booted up, select "System Preferences" from under the
apple in the upper left corner of the screen and click on "Accounts."
Note that you really only need to bypass the administrator password, as
standard user accounts are all controlled by the administrator. If you
are unable to boot the computer due to a password, proceed to Step 2.
2.
Fotolia.com">
You'll need your OS media.
Insert a Mac OS X installation
disc into your MacBook's drive. Select "Restart" from under the apple in
the upper left corner of the screen. When the computer begins the boot
process (as soon as the screen becomes active), hold down the "C" key
until you see the spinning wheel on the screen.
3. Click on the arrow in the lower right corner of the window to proceed.
(Note that the startup process takes longer when you're booting off an
installation disc.) When the menus appear at the top of the screen,
select "Reset Password" from under the "Utilities" menu.
4.
Fotolia.com">
Check your Caps Lock key.
Select the account whose
passwords you want to bypass. If there are multiple user accounts, you
will have to change them one by one and repeat the process for each
account. Write down the passwords and remember that they're case
sensitive, so check your Caps Lock key. You can also opt to leave the
password field blank, meaning you don't enter anything in the field when
it appears.
5. Fotolia.com">
A MacBook user
Quit the Password Utility and
then quit the installer. You will be prompted to make one of three
choices here, so select "Restart" at this point. As soon as the MacBook
reboots, hold down the track-pad button (or mouse button) to force the
computer to eject the disc upon
6.
Fotolia.com">
Mac passwords are stored in the Keychain.
Open the Keychain utility (found
in Applications>Utilities) to determine if there are any other
passwords that you need to know and/or change. By knowing the
administrator password, you can access every password stored in the
Keychain. To learn the passwords of these items, simply click on the
item in the list of the Keychain. You will be prompted to enter the
administrator password (as created in Step 4) and clicking on "Allow."
I hope you find it very helpful.
Thank you.
SOURCE: new apple id
If you go to https://iforgot.apple.com/cgi-bin/WebObjects/DSiForgot.woa/wa/iforgot and enter the information you should be able to get a new password. Hope this helps.
SOURCE: my password wont be accepted
Apple ID passwords require at least 1 capital letter and at least 1 number.
You have to manage your iTunes account in iTunes. Follow these instructions to change account information.
You can change your Apple ID name, password, or billing information at any time.
Choose Store > View My Apple ID, and sign in.
Click Edit.
Make your changes, and click Done.
Your changes take effect immediately.
If you also use your Apple ID in other apps, you don't need to update your information in those apps. The changes you make in iTunes apply to all apps in which you use your Apple ID.
If you have an AOL account, changes you make in iTunes don't affect your AOL account on the AOL service. For example, if you change your password in iTunes, the password you use to log in to the AOL service doesn't change.
