I have a LP0910WNR air conditioner and it keeps turning off I emptied it and cleaned the filters it works on fan wont stay while it's on auto or cool so my question is there a reset button besides
SOURCE: Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Posted on Aug 16, 2007
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
SOURCE: Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Posted on Aug 03, 2008
emissionwiz
  • 76164 Answers
SOURCE: cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Posted on Aug 22, 2008
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
How do you add feron to lg lp0910wnr ac
I would suggest taking it to your local service shop. They can add the nedded service valve and add freon.
Jun 06, 2014 | LG Electronics LP0910WNR Portable Air...
How to add freon to lp0910wnr by lg
u dont just "add" it. if it has leaked out you will have to locate the leak and fix it. just adding it it will soon stop working again. are u sure that it is the gas charge? could it be the compressor isnt working?
I get an E1 display and will not turn on
E1 CODE MEANS AIR FILTER IS DIRTY OR THE UNIT NEEDS RESET. IF SO YOU CAN TAKE YOUR VACUM AND CLEAN IT. IF VACUM DOES NOT WORK. WASH IT AND LET DRY BEFORE REPLACING. IF THS DON'T WORK UNPLUG AC FOR A COUPLE HOURS, TO RESET YOUR UNIT. HOPE THIS WORKS FOR YOU
Oct 06, 2013 | LG LP0910WNR Air Conditioner
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
To turn on the air conditioner, on the thermostat do you click it to Auto and then on the other side click to Cool? Or do you click on Fan and Cool?
If you put the fan to auto, the fan will run only when the compressor runs. the other position it will run untill you switch it back to auto. Then cool unless you require heat at night or in the morning, usaually when I start cooling season the heat stays off.
Jul 05, 2011 | Honeywell Heating & Cooling
B 2200 - Fan still working - no cool air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Dometic Rooftop RV Air Conditioner
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
DE500P Dehumidifier: Does not dehumidify even though set to dehumidify. Fan will turn on when RH above setting, and stay on, since humidity doesn't drop. Filter is clean & pail empty.
Locate and touch the cooils located, usually, above the condensate collection pan, ("pail empty"). If the coils are not cold, or cool to the touch, the unit has lost its charge of refrigerant. This would explain why the unit fan is working, but there is no condensate, as there is no coolant (charge) to cool the coils and "pull" the hunidityout of the air.
Jul 07, 2008 | DeLonghi Heating & Cooling
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
