Question about Sander Tools & Hardware - Others
I have a Stanley H-31A belt sander that needs brushes. Does anyone know the part number or which ones will work
  • Tom Gabbard
    Tom Gabbard Aug 18, 2017
    There are no brushes currenttly in the sander to measure.
  • Sander Master
  • 10,884 Answers
Take them out and measure them.
Posted on Aug 10, 2017
Testimonial: "There are no brushhes currently in the sander to measure."
SOURCE: Dyson 17 Brush Belt Broken
there is also an updated beater bar that accepts a wider belt, dyson sent it to us for free
Posted on Jul 03, 2008
rowdy45176
  • 2176 Answers
SOURCE: need help disassembling Porter Cable random orbit sander
Go to Dewaltservicenet.com and in the center of the page under needing parts type in your tool model number it will take you to another page and scroll down to the type 1 or 2 and click on it. It will bring up an exploded view of this tool. Why do you think that you need brushes? usually I have to replace the bearings and the brushes are pretty durable. Let me know if I can help further
Posted on Jan 21, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Posted on Nov 24, 2009
I have a stanley 80493 belt sander 3 x 21 model 04 I need to get a belt for it, where can I find one ?
You can contact Sears they will find the part for you or go on Stanley tool site and e m ail them the part # or u can go to ur local hardware or mini bike shop they will have various size belts
Dec 11, 2014 | Tools & Hardware - Others
I need a drive belt for a Stanley belt sander
Unless there is a model that I have never seen, the sandpaper is the drive belt on belt sanders.
Jul 04, 2014 | Hand Tools
Belt slips on Stanley belt sander model H-31A
On most belt sanders the back wheel or the idle wheel has an adjustment on it, loosen the bolt that goes through and slide back. Some have an adjustment screw that will pull or push the idle wheel. That should be on the inside of the wheel.
Mar 05, 2014 | Hand Tools
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
Need motor brushes for a stanley heavy duty 4'x24' belt sander. type: 497, model A, amps: hi-8.5, lo-7.0, volts 115, serial # 457244. thanks, tom
Hiya
I had the same problem, cannot find spares. I went to a local tool hire company and purchased two brushes (Part No. L41F10). You will need to shorten them by approx.1/4"", swap the springs and cut down the metal terminal to same shape as the original. A small 1/2 round file, junior hacksaw and about 15 minutes should get you going.
I am looking for a trigger (on/off) switch to suit my sander, if anyone can help I would appreciate it. Only other option seems to fit an inline switch to supply cable.
Jun 15, 2011 | Garden
Have a porter cable 352vs 3"x21" belt sander. was using it and blue sparks started occuring in the rotor and brush assembly. kept using as I needed to try and finish my project. No longer...
this tool has various type numbers but I checked on the type 5-6 and came up with the same number. the brush number I found is NO30461 and they run from around 3.50 to 4.00 each. If you have removed the brushes if the spring is burnt/collapsed it could have been from a loose brush cap or worse an armature problem. Before I sent it out for repair I would look at the brushes, UNPLUG tool first and remove them after removing look into the brush holder and see if the commutator (part of armature you can see) and see if it is discolored or other obvious imperfections. You can buy replacement brushes online from "ereplacementparts.com" or direct from "dewaltservicenet.com". Let me know if you need more assistance before voting and thank you.
Feb 24, 2011 | Porter Cable 352VS Factory Reconditioned...
Brushes on my sander are wearing out within 10mins
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
Parts
I have the same sander, and cannot get parts anymore, so I carefully cut out a piece of sheet metal, and drilled holes, and put it on. so it might not say stanley, but who cares? I don't. and if it doesn't last as long, who cares. its more help than I got from stanley, who was bought out in 1973 from what I read.
Oct 18, 2009 | Stanley Hand Tools
Tools & Hardware - Others Logo
292 people viewed this question
Top Sander Tools & Hardware - Others Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
