Question about Grilling
Rotisserie spits for chicken, how do I get replacements.
It's the spits that rotate the meat being cooked
    Top Expert:
  • Grilling Master
  • 43,983 Answers
Fixya does not sell replacement spits and is unable to identify sources.
Posted on Aug 11, 2017
SOURCE: Rotisserie won't stay lit
With our Kenmore, you need to increase the gas flow another 1/4 turn once it's lit.
Posted on Jun 05, 2008
SOURCE: NEED instruction manual for MECO outdoor smoker -NOT electric
If you try searching for Meco on-line, you'll go nuts.
Check Aussie here's a link for the manual.
http://www.aussiegrills.com/images/product_elements_07/pdffiles/5024-5025-5028-5029P-Stainless-Water-Smoker.pdf
Posted on Sep 26, 2009
SOURCE: I need the farberware rotisserie manual suggested
All Farberware Rotisserie Manuals are available for download at http://openhearth.info. The manual that has the prime rib recipe is http://openhearth.info/450.htm . However, I have tried this recipe, and if cooked according to those instructions, the prime rib will be overdone. I take mine off at a much lower temperature to allow for carry-over cooking. These rotisseries make the BEST prime rib!
Posted on Dec 24, 2009
  • 67 Answers
SOURCE: I bought a Euro Pro TO242RW convection oven and
Have you tried to find the Euro Pro website to look there? Have you searched on the internet using Euro Pro, model,and the word manual because there are sites that offer manuals on products. And the same thing for the rotisserie part. Maybe doing that will give you leads to look further if need be.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Posted on Feb 06, 2011
kebah
  • 684 Answers
SOURCE: Bought the GE Rotisserie oven
Visit http:///www.gehousewares.com/Customer_Assistance.aspx,
you will be able to find there how to order parts.
Regards.
Posted on Jun 18, 2011
I need to know the cooking times for my chicken
Use a thermometer and measure the chicken, keep track of how long it takes then you have the time it takes to cook that piece. It is always best to use a thermometer when cooking meat.
Generally I bake chicken at 350 degrees F. for 30 to 40 minutes. To be sure that the chicken bre asts are cooked thoroughly, use a instant digital Cooking or Meat Thermometer for the proper temperature of 165 degrees F.
These links will help.
Safe Minimum Cooking Temperatures
Meat and Poultry Temperature Guide Food Network
Internal Temperature of Chicken and Turkey How To Cook Perfect Chicken...
Mar 23, 2015 | Kitchen Appliances - Others
Rotisserie squeaks
That is perfectly normal, enjoy your chicken Sally.
Oct 24, 2014 | Toaster Ovens
Need to know how to roast a whole chicken
Cooking meat is not a good idea especially chicken, few microwaves have a higher enough temperature to properly cook it, you are using a 700 watt microwave, the core temperature is simply not high enough to properly cook the meat. I strongly recommend the regular oven for proper cooking and safety, plus it will taste better.
Mar 28, 2012 | Haier 0.7CF 700W Microwave 700 Watts...
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
I have all new burner element, starter and thermometer,,,because I had a MAJOR fire from deteriorating fire unit Now I used grill to rotisserie a chicken, cleaned everything and when using it to grill...
When you cooked the chicken on the rotisserie, did you remove the cooking grates and place a disposable drip pan on the flame tamers below the chicken? This will prevent the grease from dripping down into the bottom of the grill when you use the rotisserie. The bottom of the unit needs to be kept clean so the grease will run to the drip pan and not get caught in the bottom of the unit. When you are done cooking, if you will close the lid and turn the grill on high for 10 to 15 minutes it will help to burn off any grease build up and prevent fires in the future.
Jun 11, 2011 | Dynasty DBQ-30 (LP) Grill
How long to cook chicken sausage on the George foreman
this depends on how thick the sausages are. For sausages that are about 1 - 1 1/2 inches thick it will take about 10-15 minutes. the best way to tell if a sausage is done (chicken or pork) is to insert a meat thermometer into the end of the sausage about 3 inches deep. When the meat is done it will read 160 deg F.
May 03, 2011 | Vacuums
I have a baby george foreman rotisserie. I don't
Cook it until the interior temp is at 170 degrees F or more
Mar 08, 2010 | George Foreman GGR62 Grill
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
How to use Rotisserie?
GE has the instruction manual online at: http://www.gehousewares.com/products/countop_oven_rotise_1066410585855.pdf
Make sure you look at the cook times. The manual suggests using a separate timer (I use my regular oven's timer if I'm not cooking anything with that at the time) I've been reading a lot of negative feedback about this product but I love mine and use it regularly.
Nov 21, 2007 | GE 168947 Toaster Oven with Convection...
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
