Question about Frigidaire Refrigerators
Odudr Frigidaire refrigerator beeps ever hour for the past two weeks or so. Water filter has recently been changed.
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Posted on Aug 24, 2008
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
  • 10865 Answers
SOURCE: Frigidaire filter problem..
After changing the filter it is necessary to reset the filter status light. Press the filter status reset button for 3 to 15 seconds until the green light flashes.
If you want to look at the entire service manual you can access it at : http://www.fixya.com/support/p61551-frigidaire_frs26r4a_side_by_side/manual-4115/page-14
Posted on Feb 09, 2009
Maytag317
  • 1136 Answers
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Posted on Jul 17, 2009
SOURCE: GE smartwater filter (model GXRLQR) stopped working...help!
These replacement filters (GXRLQR) are FLAWED straight out of the factory. The problem is in the 2 little "teeth" nubs that stick up near the center circle of the filter. When the filter is twisted and inserted, these teeth push up on a tiny black spring loaded valve in the body of the filter, alowing water to pass through up and out the spigot. The flaw is that the "nubs" are too short and do not push open the spring valve far enough, reducing flow to a semi-trickle, even with a brand new filter. GE seems to think this is not a problem.
Solution=stick a $0.25 garden hose rubber washer in the top of the filter and screw it in. You may have to try a few times to get it to work and seat properly. When it works, you'll immediately get a nice super flow of water. Better than upgrading to a $200 filter system recommended by GE...
Posted on Sep 12, 2010
Recently Frigidaire s by s emitting a periodic beeping sound, in early morning! What would cause this? Not all the time!
Our refrigerator was doing that and we found that it was the water filter for the water in the door that needed to be replaced.
Oct 06, 2016 | Frigidaire Refrigerators
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 25, 2015 | Refrigerators
Need to get water back working
I appreciate your inquiry, Michael Dempsey!
From what you have described your Frigidaire refrigerator is not producing ice or water. You have stated that the filter has been changed and valve has been opened, you still do not have water. This could be a potential problem with the water valve or water line. I would recommend performing a manual defrost, it is possible that the line has been frozen, within your refrigerator. In order to defrost it you would need to disconnect power from the refrigerator for four to six hours. I hope this information has been helpful. -Matt
Feb 16, 2015 | Frigidaire Refrigerators
Water dispenser on my 3 year old side by side FRIGIDAIRE PROFESSIONAL FPHS2386LFO is not working, It makes ICE but no water I can hear motor when I try to use dispenser
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Dec 26, 2014 | Frigidaire FPHS2386LF Professional 22.6...
Water not coming out
Hi Leslie, this is JK. I understand that you are experiencing concerns with your refrigerator's (model FRS3R5EMB) ice and water. Have you recently changed the water filter? If you have not changed the filter in the past three months or the filter is clogged you may experience a slower water pressure or hollow ice cubes. However, if you have recently changed the filter and are still experiencing this, simply re-install the filter to ensure that it is installed correctly. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Apr 18, 2014 | Frigidaire FRS3R5EMB Side by Side...
Stinky water from frigidaire side by side.
Check your outlet line, probably it is jammed. Thanks
Oct 04, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Feb 09, 2009 | Frigidaire FRS26R4A Side by Side...
Ice with Sediments
in the water supply line to but well before the refrigerator fit a ceramic water filter
that has a filter so fine that many germs cannot pass through
Nov 26, 2017 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
