Question about Tablets & eReaders
Tablet if frozen in select boot mode - Tablets & eReaders
Hi, can u remotely restart my tablet? it's been frozen for 2 days
there is no possible way to remotely restart a tablet but there is a way to do it press and hold the power key for about five seconds and this will force the tablet to turn off or reboot the android system and it should be fine however if it freezes again this can be an issue with the android system itself and the tablet will need to be reset (resetting android for some tablets: press and hold the power and volume down (or volume up) key and this will boot to recovery mode for some others say like samsung press the power volume up (or down) along with the home key to go into recovery mode)
Feb 22, 2017 | Tablets & eReaders
Why do my tablet keep frozen up
Clear the cache. Procedure varies depending on the tablet and android version. Usually found in the settings menu or can be accessed by turning off the tablet then press power and volume up and holding both until the boot menu comes up. Use the volume up/down buttons to scroll to wipe cache then press power to select.
Oct 08, 2016 | Tablets & eReaders
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    How to do a factory reset on a Nobis 7.85 tablet, it is blocked
    Follow these steps:
    1. Press the power button and the home button together or Power button and Volume button together for a while, long enough till the Android boot mode screen appears. Press home button to reach the options under boot mode. Navigate through the options using volume key and select "Wipe Data Factory Reset"option using shortcut menu button. Again navigate to the option "delete- all user data" and select it using shortcut menu button. (Make sure memory card is not inside; otherwise the data on it will be lost). After the data is deleted, a message saying "Data Wipe Complete" appears. Press the shortcut menu button to reboot the tablet again. Now, your tablet is as fresh as a new tablet
    Feb 05, 2015 | Tablets & eReaders
    Tablet got frozen on go screen so I pressed reset now it won't do anything not even turn on
    What tablet brand is it? Need to configure reset duration on hold buttons
    Feb 02, 2015 | Tablets & eReaders
    How do you stop demo mode on lexibook junior tablet? just bought it for xmas and wont let us do anything but keeps playing demo video over and over
    Your tablet is stuck in demo mode, to reset the demo mode shut off the tablet, keep pressed at the same time power+volume up buttons, the tablet will boot in recovery move, the last selection of the menu is the demo mode feature 0n/off
    Dec 29, 2014 | Tablets & eReaders
    I have my grandaughter tesoar tablet is frozen on the white screen with tesoar across the screen i need help
    Hi, you need to do a factory reset!
    First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
    let me know how you get on!
    Oct 18, 2014 | Tablets & eReaders
    How do you fix a frozen tesoar tablet
    Press the reset button hole with a pin first.
    If that doesnt work then go into recovery mode usually by pressing the power button and volume up buttons at the same time then selecting restore tablet option.
    If you tablet is corrupt you will have to sideload or reinstall the os from a usb stick.
    May 10, 2014 | Tablets & eReaders
    Tablets wont boot up just shows arnova on screen and shuts down
    I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
    How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
    Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
    To access Recovery mode on the ARNOVA 10bG3
    To access to the recovery mode:
    1. Hold down the volume button + and press the ON/OFF button.
    2. Once the boot logo ARNOVA is displayed, release the volume button +.
    The ANDROID green robot is displayed.
    3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
    The Android system recovery screen is displayed.
    a. Use the volume buttons to navigate
    b. Use the ON/OFF button to select an option
    To restore the default parameters of your tablet:
    1. In the Android system recovery, select Wipe data/factory reset;
    2. Select Yes -delete all user data.
    3. Select Reboot system now.
    Your tablet reboots. Redefine your parameters through the wizard.
    Your tablet is restored to its default settings.
    To access Recovery mode on the ARNOVA 9G3
    1. Hold down the Home button and press the ON/OFF button.
    2. Once the ARNOVA boot logo is displayed, release the Home button.
    To access Recovery mode on the ARNOVA 8cG3/8bG3
    1. Hold down the volume button - and press the ON/OFF button.
    2. Once the boot logo ARNOVA is displayed, release the volume button -.
    Sep 16, 2012 | Tablets & eReaders
    Tablets & eReaders Logo
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
