Question about GE APN10AA Portable Air Conditioner
Danby dpac10030 Won't drain into the bucket, it is bone dry. Water does seem to get all over the floor though.
3 Suggested Answers
SOURCE: APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
Posted on May 27, 2008
  • 334 Answers
SOURCE: drain hose in floor drain but fills up water bucket
wow, that's a weird one there. just to check, you did turn thr drain connection all the way down and remove the cap? nothing inside the drain connector? the hose is not too small or run too far? is the water coming out of the hose and in to the bucket at the same time if it is I would think ther is an internal leak somewhere and take it back for an exchange if new. good luck let me know if this wasn't any help for ya
seth
Posted on Jun 12, 2009
Humidifier is draining on floor while bucket is not yet full- why?
ck that float level in corner of bucket is free and moves well , also verify that unit is level as this affects the float and amount that bucket can hold , also a ck that drain hole that allows water to enter into bucket is not partways plugged with something , should be pencil size hole there
Oct 01, 2014 | Danby Dehumidifiers
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
Water leaking from beneath unit. Some water enter buckets some leaking onto floor. Can't use the unit it leaks so much.
Look for the drain tube which sends the water to the buckets. It may be disconnected or misaligned allowing the water to go the wrong way. The tube can also be stopped up. Blow through it to clear.
Jul 22, 2011 | Danby Portable Air Conditioner
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
Danby Silhouette leaking
check that the removable bucket did not alter a water guide near the cooling fins
Jun 05, 2007 | Danby DDR600R Silhouette Dehumidifier
GE APN10AA Portable Air Conditioner Logo
278 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
