Question about Kenmore Dishwashers
I have a kenmore dishwasher Model #36314471790. I was replacing the dishwasher drain solinoid gasket and the drain shaft came out of the motor? Do i just push it back in and reseal with the gasket?
tzweeb
  • 318 Answers
SOURCE: dishwasher not draining - Kenmore dishwasher model 15754
depending on the age of this unit it may have food blocking what is called the "check valve".
on most models it is mounted right on the outlet of the pump housing. one model uses a 4 inch plastic tube style device and is about 1/2 inch on the pump and 1" on the hose. inside of it is where the food items can block the check valve. remove the hose and unscrew the check valve from the pump and see if something is blocking it.
on newer units the check valve is built into the drain hose, if you hose has a 90 degree elbow molded into it where the hose hooks up to the drain pump. once again take the hose off and look inside the hose or try to blow through the hose and see if the hose is clear.
good luck tom
Posted on Dec 31, 2008
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: A Kenmore model 15522000 type 280-1 dishwasher will not drain
I scooped out the water and found a spoon jammed in the drain area. Works like a charm now.
Posted on Feb 05, 2010
Leaks water from under dishwasher, some one suggested the fill valve assembly needs replacing???? kenmore
Hi
Thanks for using FixYa. If your dishwasher leaks, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Bosch shu8805 (2002 model)
HI,
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Jul 30, 2009 | Dishwashers
Kenmore 17369 not draining
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher Leaking
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water seeping in dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Kenmore ultra wash model 16625691
looking for a black/almond front replacement panel for my Kenmore dishwasher model #16625691. Any sugguestions as to where to find one?
Oct 17, 2007 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
