Question about Electrical Supplies
Where is oil filter and drain plug on Onan 4000 generator that I have on my rv
5 Suggested Answers
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
  • 142 Answers
SOURCE: onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Posted on Jul 01, 2010
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Onan generator service codes
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Oil Leak
Need model and serial number off this unit in order to proceed.
However, if it is a KY model, with an about 2" cover underneath. That cover is blocking the oil drain plug. It is possible that the oil drain plug is leaking. Remove and drain oil into pan. Clean the plug and add plumbers tape to the plug and install. Then fill the unit back up with oil.
Mar 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Sep 27, 2008 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
49 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
