Question about Weedeater Garden
Line on crafstman weedeater
Electric weedeater, when i wind line on, it comes loose as soon as i install in the weedeater
  • Weedeater Master
  • 5,416 Answers
Wind it in the other direction.
Posted on Aug 10, 2017
Testimonial: "I have wound line lots of times, i do it just like the manual. After i hook it in the holding slots and go to thread it through eyelits, it comes undone. Sometimes it works."
    Top Expert:
  • Weedeater Master
  • 42,757 Answers
Winding it on in the wrong direction
line is installed in a counter clockwise direction
Testimonial: "i am winding it the right direction"
  • Bill Boyd Aug 10, 2017
    are you removing the spool then winding the line on then installing it and then putting the ends through the eyelets
    when you are looking at the cutter head you have to wind it to the left
    winding it on in the wrong direction gets you the problem you refer to
2 Suggested Answers
panilling9
  • 284 Answers
SOURCE: I have a weedeater brand weedeater and need to
if its the newer type all you need to do is grab the black knob at the bottom of the trimmer head and pull it carefully straight towards you and it should pop off
wind line on the spool in the direction the arrow shows you there is a small hole you put the line in to start the line before you wind it it is labeled .065 or .080
wind about 10-15 feet of either .065 line or .080 line and lock the line in at the edge of the spool and thread the excess thru the hole and push spool back on and pull each line until it unhooks from where you locked it in .
this is the directions to the weedeater heads and spools mostly used on this product.
if its two lines then pull out 20 feet of new line cut it and put the two cut ends side by side and insert the cut ends into their respective holes in the spool and wind in the direction of the arrow until you wind to the loop then cut the loop lock your lines into place and thread it thru both holes keeping the lines kind of tight and push the spool onto the housing as it snaps in pull each line to unlock it from where they were held so the bump feed will work.
hope this helps you
Posted on Jun 08, 2009
I picked up a Crafstman chainsaw mod 316.350840. Its all in peices which is not a problem except for the carb. it has 3 fuel line ports. what is the 3rd one for?
fuel return line back to the tank
if it has a primer bulb , one line will go there , one for the suction line for the diaphragm and the return line for excess fuel back to the tank to prevent flooding
go google and down load the pdf version of the workshop manual
Sep 25, 2016 | Garden
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Gas line routing weedeater
What particular model, i can send you the IPL
Jul 30, 2012 | Husqvarna 530069599 Weedeater Fuel Line...
Crafstman .25cc Weedwacker
clean the carburetor and clean the fuel filter.
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Jul 23, 2009 | Garden
Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Jul 03, 2009 | Garden
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
Garden Logo
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
