Question about Haier Heating & Cooling
My haier hpp12xct-lw is accumulating water in air mode
  • 1,608 Answers
So it's likely not fully evaporative. Must be high humidity and auto evaporate can not keep up. It just means your unit is working great. Drain it!
Posted on Aug 10, 2017
2 Suggested Answers
johndendulk
SOURCE: Problem with Haier CPN10XC9 Portable Air Conditioner: water accumulates around bottom of filter area
Samsung E163 EEPROM option error? Program the right option codes!! In my case the complete airconditioning installation (3 x indoor and 1 x outdoor unit) didn't work because the E163 code was showed on one of the indoor unit. After I followed the procedure (remove batt from remote control, put them in again holding down the right knobs, etc see the manuals you can find on the internet) I programmed the right codes within 5 minutes and the problem was fixed, the error code was gone and the complete installation was working again. So don't replace boards, electronics etc....just put in de right option codes. John, Netherlands.
Posted on May 27, 2012
Leeking water a lot
Condensate water accumulates in the evaporator.There is a tube that drains the water out of the evaporator to the condenser side where the fan picks it up or an external drain. The tube is plugged. It needs to be cleaned out.
Jul 05, 2015 | Haier 12,000-BTU Commercial Cool Portable...
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
Unit not dehumidifying
anyway the dehumidifing mode works like in cooling mode,try if it working.
Nov 29, 2013 | Haier CPN14XC9 Air Conditioner
ZCF/LW-17-2 Remote Control AC-5620-36
Following amazon item link can be compatible for your Haier ZCF/LW-17-2
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for Haier HRRM Air Conditioner Remote Control Model...
Jul 28, 2013 | Haier ZCF/LW-17-2 Remote Control...
Fan is making rubbing noise
Time to have an expert look at it as it might be a fan about to fail or something worse.
Aug 30, 2012 | Haier 8,000-BTU Commercial Cool Portable...
I have the Commercial Cool Model# CPR07XC9-LW 7000 BTU and it has been shutting down in the middle of the night. It beeps and a red light flashes on it. What does this mean?
It means that condensed water has accumulated in the unit. In the rear, on the bottom right, there is a water outlet drain. Tilt the unit slightly to drain the water in there. Be sure to unplug the unit first.
Jul 13, 2011 | Haier Heating & Cooling
How do i change the time? I'm trying to program the remote.... Haier ZHF/LW-17-2
Open battery compartment. Use a paper clip to press the little button marked "CLK". Set hours and minutes with buttons on front. Press button again with paperclip to save the settings.
Jul 06, 2010 | Haier HWR12XCB Air conditioner
Water pooling on unit outside of window
There will be a drain at the lower end of the unit, this should be connected to suitable piping and taken outside. Condensate drain soakaways are available if no suitable drain is available for it to discharge into. Try to use rigid plastic piping where possible.
Sep 08, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Water leek
Where is your AC leaking at, can you tell? This is common, but the leak of water should not end up in your house--but outside; this occurs as a result of the failure of your AC tubing or pump. The accumulation of water is a part of the normal process of condensation. Here's a really good diagnostic article that talks about water accumulation and leaking AC systems:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm
Read the article, and, actually, your best bet may be to take advantage--towards the end of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area (click the link that sasy"Find A/C Contracts. Get Up to 4 Quotes"), and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern whether your AC tubing or pump is the problem for your water accumulation.
Aug 05, 2009 | Haier HPAC99ER Portable Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
