Question about JVC Audio Players & Recorders
I have an old JVC AL-A158 turntable with no receiver or speaker. There is an attached wire with a white and red plug. A record plays, but the sound is very low. What do I do to get sound? Thanks!
    Top Expert:
  • JVC Master
  • 40,418 Answers
The "attached wire with a white and red plug" should be connected to an amplifier.
Posted on Aug 11, 2017
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
  • 19 Answers
SOURCE: I have just hooked my ion ttusb05 turntable up to
Go to control panel, open sound, select playback tab- select your speakers-not the USB Audio Codec. Apply and click ok.
Posted on Dec 23, 2009
  • 8546 Answers
SOURCE: record only plays through one speaker
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Posted on May 01, 2010
  • 5318 Answers
SOURCE: When playing records on my turntable, the right
Check the wires to the cartridge, they can come lose and need to be tight. If that doesn't solve the problem check or replace the connecting cables. You can confirm it's not the pre-amp of your amp by just swaping the cables. Then the left speaker should play up. If it is still the right, then there's a fault on the pre-amp. But it could be just bad soldering somewhere. Also take the bottom of the turntable and check the soldering of the cables inside it.
Posted on Dec 08, 2010
  • 271 Answers
SOURCE: I need to put the belt back on my JVC al-a158 phonograph
To replacea turntable drive belt.Copyright.., JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT cansupply replacement drive belts for all turntables
Posted on Nov 13, 2011
Testimonial: "Thanks. It worked out great. I appreciate your time and effort."
My Al 300 jvc no sound coming from turntable to speaker cassette radio working OK
Unplug the red and white leads. With the amp turned on to full volume, touch the sockets the leads plug into with your finger. If you hear a big buzz. The amp is OK. If you don't the cartridge pre-amp inside your amp has failed. It will not effect any other parts of the system, cassette, radio, etc.
If you do hear a buzz. Then the cartridge is faulty.
Dec 21, 2015 | JVC Audio Players & Recorders
I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Feb 09, 2014 | Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
Jul 15, 2011 | Audio Players & Recorders
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
I was wondering what the extra wire attcahed to the audio cords it looks like a speaker wire
the bare stripped wire is for grounding the turntable to the receiver to eliminate any hum sound. If after connecting both phono plugs, you only get sound from one channel on the turntable but sound plays out of both channels on all other inputs then replace the phono plugs as this is the most likely problem.
May 27, 2009 | Audio Players & Recorders
New speakers to an old (1960s) record player
It is difficult to say with 100% confidence because the pictures are out of focus, but it looks like you have just a regular turntable. The wire connections you show are the bridge between the tonearm and the external RCA style cables. The extra wire (#5) is the ground wire. You should be able to connect this to any receiver that has a phono input.
For confirmation, can you update this with the model number of the turntable? That will allow me to confirm what I have stated above.
Nov 13, 2008 | Audio Players & Recorders
Mar 02, 2008 | Audio Players & Recorders
85 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
