Question about Sewing Machines
My needle suddenly won't go up and down or from side to side. Is there a fuse I can change to see if that helps?
I turned the machine on and started to sew. The needle hit the presser foot plate because it wasn't centered (Maybe I hit something accidentally?)
  • Sewing Machines Master
  • 12,285 Answers
What's the make & model of your machine?
Posted on Aug 10, 2017
  • 106 Answers
SOURCE: sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Posted on Apr 05, 2008
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
  • 1116 Answers
SOURCE: my kenmore sewing machine needle is coming down on presser foot.
Check the needle to make sure it is inserted with the flat side of the shaft toward the back of the machine.
Also, check to be sure the needle is not bent.
Remove the presser foot and see if the needle clears the opening in the needle plate and pulls up the bobbin thread.
If all of the above checks out, switch to a presser foot with a wider opening.
If not, the machine needs to be serviced as it may be the timing has to be adjusted.
Whenever you pick up a machine that has been serviced, try it out before taking it home.
Posted on Mar 17, 2010
  • 1788 Answers
SOURCE: I keep breaking the needle because when the
Refer to your manual, it gives all sorts of reasons for the needle to break, wrong bobbin size, scratched plate, needle being inserted wrong. If, you do not have your manual go online to
brother-usa.com and download one for free.
Posted on Sep 11, 2010
  • 16 Answers
SOURCE: Presser foot is crooked and right needle hits the
Have you checked to see if the needle is bent. If it is replace the needles. If not you may have to remove the cover hiding the arm, lossen it up and ajust it straight by turning the manual nob slowly.
Posted on May 12, 2011
My up and down needle handle stopped turning all of a sudden. Why?
Without the make & model, we are really limited in providing an answer.
If it is an older mechanical machine, it may be seized due to lack of frequent cleaning and oiling.
Wheel on right side that controls the needle up and down is very tight...
Oct 05, 2017 | Sewing Machines
The tension will not stay set . It sews great and then suddenly starts looping!! Like carpet!!and no bobbin shows through on back side at all help!!!
Ewww! Wondering if the tension mechanism has gone haywire.
First, change the needle. (Is the thread still in the correct path or has it "jumped" out of place? If so, try slowing down the machine.) Remove the thread. RAISE the presser foot to insure the thread seats properly in the tension disk and rethread from the beginning. Check that the bobbin is threaded properly. Check the tension setting and retest.
If it is still malfunctioning, it may need service.
Mar 09, 2016 | Janome MB4 Four Needle Embroidery Machine
Sewing machine needle won't go down to catch bobbin thread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
also make sure the thread has not come off the thread take up lever
if none of these suggestions help, then you should consider
taking the machine to have it service, to see if it's out of time
Jul 31, 2012 | Brother Sewing Machines
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
My sewing machine won't zig-zag stitch
There is usually one source for this problem, and it's easy to fix. Take the end cap of your machine as if you were changing a light bulb. Now you are off...When you switch from straightstich to zigzag, the levers operate across and inside the body so that the needle shaft, you watch it going up and down, can also move sidesways (but only a few mm's (about 3/16 inch)) The needle shaft should both go left and right, freely. It is hinged at the top but half way down ththe shaft it "floats" in a two sided guide. This sounds complicated but it truly is NOT. What happens to neglected machines is that "gunge" forms in the sliding parts and stop the left and right deflections. You my need to prise open the shaft from it's guide to start with (be gentle) but a few drops of oil normally soon allows the needle shaft to slide side to side.
When you can shake the needle shaft from side to side BY HAND (with the machine set in the zigzag mode) replace the end cap and start zigzaging.
And in future oil your flaming sewing machine.....
Apr 29, 2012 | Husqvarna Sewing Machines
How to change a needle
Remove screw at the bottom of the needle bar while holding needle carefully so it doesn't drop down into your sewing machine.
Push new needle all the way up until it won't go any farther and make sure the flat side is in back, the rounded side should be facing you.
Tighten screw securely.That's all there is to it!
Hope this helps.
Jimmy
Apr 01, 2012 | Sewing Machines
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
While sewing, the needle suddenly hit the side of the foot-plate which bend the needle, but now the entire machanism is stuck and won't move up or down. How can I fix it and what is the cause of the...
hi there
1- how old your machine ? please check needle par play left and right or no? maybe lower needle bar bushing need to change.
2- maybe ur presser foot played need to change it but check firist.
3- sometimes when needle is broken there is small metal goes insaide the hook and make it dosn't move up or down, if you can adjust timing for hook please remove the hook and check your machine by hand move or not?
4- maybe some thread goes insaide the finger ( stopper for hook ) check this earia .
Best regards
ashraf abozid
aabozid@hotmail.com
Aug 28, 2010 | Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
