Question about Ovens
Hi we had a power surge and now the control panel on my oven is all messed up the lower oven does not turn on, oven light does no time work on either oven etc is there a way to clear this?
5 Suggested Answers
SOURCE: older Whirlpool RB170PBX both ovens out
We have an old Whirlpool oven, and the lower heating element is no longer heating above 250 degrees. Is this heating element something that can be pulled out -- like the stove burners can be pulled out of electrical sockets -- or is it attached to wires, requiring an electrician to replace the unit?
Posted on Feb 09, 2008
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
  • 277 Answers
SOURCE: double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Posted on Jul 26, 2010
  • 152 Answers
SOURCE: Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Posted on Mar 16, 2016
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Double oven control panel just quit after power surge.
Jul 26, 2010 | GE Profile JTP18 Electric Single Oven
My Frigidaire Oven display panel won't come on all of a sudden. Burners and oven light work. It could be from a surge in electricity. How do I 1) check fuses or breaker? Where are these located? How could...
If the burners and oven light are working, then you have power coming in. It's most likely a defective EOC. If you haven't tried turning off the circuit breaker for 5-10 mins to reset any glitch associated with a surge or spike, do so. If this doesn't reset the control, the EOC will need to be replaced.
Jan 05, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
Oven turns on by itself without being preset to do so
You may have already called service and that is a good Idea since this could be a fire hazard if something was left in the oven when it comes on.
First I would check all the key lights on the oven controls to ensure that they do light. We have the same stove and several times we have brushed the top panel and turned things on accidentally. Ensure that the audible alarm is on/working - it helps.
The next strategy has to do with all the myraid of oven control modes if there is a defalult - reset to it . Otherwise cancel all timing or alternative mode methods for controlling the oven.
Has there been power outages or power surges correlating to these turn on phenomena? A surge protector if such a thing exists may be needed and static electricity may play in this as well - good luck.
Nov 18, 2008 | Ovens
GE JT930 Electric Single Oven Problem not working
power controller board inside control panel upper right side, normally gets trashed with power surge from utility company power issues
Oct 07, 2008 | GE JT930 Electric Single Oven
Oven not working
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
May 19, 2008 | Fisher and Paykel AeroTech Double OD302...
Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Nov 05, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
