Question about Dell Computers & Internet
How do I replace the Bios battery in a Dell Precision 4600 Laptop. Which videos will show me the correct disassembly procedures? Can you supply the correct part no.?
  • Dell Master
  • 5,381 Answers
Do you mean the Dell Precision M4600 mobile workstation. According to the User Manual, the coin cell battery is a 3V CR2032 lithium ion cell (page 117).
To replace this battery, turn off and close the laptop and remove the power cable and all external cables, docks and accessories. Make sure that the work surface is clean. Turn the system over and remove the main battery by sliding the release latch towards the center of the computer. Turn the system right side up and open the display. Press the power button to ground the laptop and drain any capacitors. Remove any cards from the card slots. Close the display again and turn the laptop upside down. Touch bare metal on the system to ground yourself relative to the computer.
Remove the two screws that hold the base cover onto the 4600. These are on the edge of the battery compartment on the side nearest the battery release latch. Press the rubber feet on the bottom of the cover towards the rear of the system to disengage the bottom door. Then remove the base cover. (See page 23 of the manual.)
Carefully disconnect the coin cell battery from the system board. There is a small white connector at the end of the wire. (The coin cell compartment is near one of the two system fans.) Pry up the current coin cell battery out of the adhesive and remove it from the computer. The connect the new battery to the coin cell compartment and reconnect the wires to the system board. See pages 49-50 in the manual. Replace the base cover and the battery.
I can't find a video for the coin cell battery replacement. However, the manual is available here: http://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_precision_mobile/precision-m4600_service%20manual_en-us.pdf . However, the first part of the following video: http://www.dell.com/support/troubleshooting/SupportVideos/OpenSingleVideoPlayerTab?embedCode=lmczhmZTpjgWeUO_e7UOBIx5jw4zhtez . shows disconnecting the coin cell battery from the system board (when the system is completely out of the case.
I hope this helps.
Posted on Aug 10, 2017
RescueTechLA
  • 2653 Answers
SOURCE: Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Posted on Mar 04, 2009
  • 7 Answers
SOURCE: Screen size on start up and bios is small but fine in windows
There is an option on bios that says LCD panel exp
Posted on May 29, 2009
  • 5 Answers
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Posted on Jun 07, 2009
SOURCE: capturing video from a Sony minidv drc36 to a Dell precision
with sony mini dv handycam how to capture on pc
Posted on Aug 22, 2009
  • 3940 Answers
SOURCE: how to replace Dell Precision M6400 keyboard?
http://support.dell.com/support/edocs/systems/wsm6400/en/sm/keyboard.htm#wp1179980
Removing the Keyboard caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage on www.dell.com at: www.dell.com/regulatory_compliance.
  1. Follow the procedures in Before Working on Your Computer.
  2. Remove the LED cover (see Removing the LED Cover).
  3. Remove the four M2 x 3-mm screws along the top of the keyboard.
notice.gif NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
  1. Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
Posted on Oct 02, 2009
How to reset forgotten bios password on a dell precision 220
If you know the current password just boot the machine and look for what key to press to get into the Bios or Setup. There you can change it if you know the current password.
If you don't know the password, then you will need to remove the CMOS battery from the motherboard and let it sit for a couple of hours. This will cause the computer to clear memory of everything. Then replace the CMOS battery and start the machine. Unfortunately you might have to disassemble the laptop to get to the CMOS battery.
Mar 15, 2012 | Computers & Internet
How do you reset/break a dell Vostro Bios password? I have a Vostro 1500 from Dell and there is a BIOS locking me from accessing it. I want to break/reset it so I can access essential settings in the...
1.Power down the computer by clicking the "Start" and "Shut Down" button. Allow the computer to turn off entirely and wait about 30 seconds. Unhook the AC adapter from the computer. Turn the computer over and locate the battery compartment near the display hinges. Push the latches away from each other to unlock the battery. Remove the battery from the laptop.
2. Locate the memory compartment found on the opposite end of the laptop's bottom. Unscrew and remove the single phillips-head screw using a precision screwdriver. Pry the metal door off the laptop using the screwdriver.
3. Locate the memory module. Directly under the module is a blue plastic sleeve connected to the mainboard with a single wire. Disconnect the wire and wait about 30 seconds. Reconnect the wire to the mainboard and replace the metal memory door. Secure the door to the laptop by tightening the phillips screw with the screwdriver.
4. Reinstall the laptop battery, inserting the tabs first and clicking downward. Plug the AC adapter back into the laptop. Flip the computer over and power on the system. Enter the BIOS and change the password if desired, or leave it blank for no password prompt. (Source: How to Reset the BIOS Password on a Dell Vostro 1500 Laptop ' eHow.com)
Please leave feedback for this answer, thanks.
Mar 13, 2011 | Dell Vostro 1500 Notebook
My Dell Dimension 4600 computer will not turn on when I hit the On button, Instead it show a small greenish light near the On button under a Power symbol. I have checked all the cables and cords and...
Open up the side panel of the PC case, remove the BIOS battery for about a minute. Then reinstall it in the correct orientation. This will clear the BIOS to default.
You would have the best possible chance of success.
Try use another Power Supply, and try using onboard graphics and Graphics card to test if it is the problem.
If it works after resetting the BIOS the enter the BIOS by hitting del key, check the manual, at statup, and enter the correct date and time.
The day it stoped working, was it fairly warm? PC could have overheated and fried the Northbridge, thats the chip under the heatsink below your CPU cooler!!!
In that case you would have to purchase a new Mainboard!
Please tell me if this sovles your problem.
Please take the time as I have to rate this solution.
Thanks.
Oct 31, 2010 | Dell Dimension 4600 PC Desktop
How to break bios password for dell precision m70 laptop
The only way for you to remove BIOS password is to remove the CMOS battery inside the laptop. You can go to support dot dell dot com.
Cheers!!
Sep 02, 2010 | Dell Precision M70 Notebook
How to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
Jul 03, 2009 | Dell Precision 360 PC Desktop
How can i reset bioss password....dell precision m65
my friend the new laptop has no jumper anymore on the board, and u cannot reset the bios this easily, some laptops u still can do that by disconnecting the bios battery and connect it after some minute, but if this doesnot work donot destroy ur laptop.
Jun 14, 2009 | Dell Precision M65 Notebook
I need to replace the battery in my computer. I have the manual. Has anyone done this? Can you follow the procedures in the manual or is there a better set of instructions to complete this job?
Here is a step by step tutorial from Dell:
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/battery.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 07, 2009 | Computers & Internet
Boot up
Maybe your CMOS battery is low on power. Have it replaced with a new/good one.
Hope it works for you.
Amfo_1
Mar 01, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
67 people viewed this question
Alun Cox
