Question about Refrigerators
My door is very hot to touch, more than anyone else's,and my electric bill is very high
  • 2,022 Answers
Posted on Aug 10, 2017
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
Refrigerator model Tbx14sybblww is always running. Is it going to run up my electric bill.
Three things to check here;
\Is the door seal allowing warm air into the refrigerator; you usually have an ice build up too
\The thermostat could be old and not sensing temperature; test this with a thermometer
\There could be a very slow refrigerant leak stopping the fridge from working; this usually means a very hot to touch compressor
Apr 03, 2011 | GE Refrigerators
It seems something holding the door to shut all the way the upper latch does not go in all the way.
The door does not close all the way and the latch is not supposed to go in all the way. If you are not getting any error messages, don't worry about it. Try the dollar bill test. Close the door on a dollar bill and then pull the dollar out. you should feel some resistance, if not the door is miss-aligned. Fixing the oven door should only be done by a factory certified tech because
The oven door provides three primary functions:
1. To protect the operator from the hot
convection airflow.
2. To protect the operator from exposure to
microwave energy.
3. To actuate the interlock switches.
Sep 23, 2010 | TurboChef TORNADO Electric Oven
Will oven work without outer window pane on door?
Yes,it will work. Please be careful and do not let anyone touch the door while the oven is hot.
Nov 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Very hot between side side doors.
this unit is working just fine, do not be concerned.
it is part of the condenser side, of the refrigerant cycle, keeping frost from forming around the door seal.
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Replace seal
Take the door off. You will find a 1/4" screw every 3" to 5" all the way around the door. Remove every one of them. It amy take a couple trips around to get all of them. Before you attempt to install the gasket, soak it in hot water for about an hour (while you are removing the old gasket). This will soften the rubber so that you can work with it. After you have replaced the gasket and re-installed the door. Take a rag soaked in hot water and wipe it slowly around the gasket. This will warm it again. Now take Vaseline and smear a small amount all around the gasket. Close the door and let sit for 15 to 20 mins. Now take a dollar bill, open the door and close it on the bill so that a end of the bill is sticking out. Now pull the bill out slowly. The gasket should have a snug grip on the dollar. If not re-heat it then close the door so that the magnet will pull and stretch the gasket until it touches the box. Do this all around the door to insure that the rubber of the gasket has expanded and allowed the magnet to reach the fridge case. If you take your time, you should have no problem. Good luck
Please rate solution
Sep 07, 2009 | Candy CPCA270FFK Bottom Freezer...
I have a new 1 hp hayward on my new inground. It is on it's on electric meter and my bill has been $130/month for the pump alone. It's very hot to the touch. Is any of this "normal"? Everyone that i...
Yes, it is normal for a motor to be hot to the touch.
The motor draws on the order of 8 amps at 220 volts. The calculation:
Watts = Volts x Amps = 220 x 8 = 1760 watts
At, say $.20 per killowatt hour, the cost to run the pump 12 hours per day for a month =
1760 Watts x 12 hours/day x 30 days / 1000 watts x $.20 = $127
You can substitute your actual numbers for the variables, to get an accurate cost.
Charlie
Aug 13, 2009 | Hayward Sp2807x10 Max-Flo 1 Hp Swimming...
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Water heater problem (no leak on floor)
It sounds like you might have scale buildup on the elements. If its a dual element unit it will ground it self out and it sounds like its boiling. constance usage of electricity, but no water usage. Drain it, and pull the element and replace the element.
Jan 17, 2009 | Water Heaters
shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Nov 23, 2008 | Ruud Central System Air Conditioner
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
