Question about The Audio Players & Recorders
TV # TC-P42GT25 / I NEED TO KNOW IF THE DIGITAL -OPTICAL IN THE BACK OF TV IS ACTIVE & WILL IT OPERATE WITH THE TV SPEAKERS ON? THANK YOU
SOURCE: Help connecting digital optical cable with DSX-V412
Found an online user manual.
Fixed the problem.
Posted on Jan 04, 2009
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need.  Set the output on the source unit to optical out.   Connect the optical cable to the amp.  Connect the speakers to amp.  turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
Posted on Feb 11, 2009
  • 118 Answers
SOURCE: Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Posted on Dec 08, 2009
  • 85 Answers
SOURCE: NO OPTICAL SOUND I connected HDMI from reciever
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Posted on Jan 07, 2011
ZJLimited
  • 17970 Answers
SOURCE: samsung 34 X optical zoom digital 1200X I need
Click over image to download your Samsung-Camcorder-SCMX20ER-User-Manual...
Hope helps with this (remember to rate and comment this answer).
Posted on May 29, 2011
How can attach external speakers with RCA plugs or a mini-plug? Is the digital audio output the only connection for audio output? (The model is TC-P50G25)
Well isn't this just a find how do you do!!
It appears that on this set there is no headset or other audio connection other then the optical?
It appears the only way to a traditional RCA audio jack is via a special adapter. See image. Inexpensive not sure of the quality of audio.
The best way would be to purchase a sourround sound speaker amp system with 5 speakers plus base woofer. These surround sound systems are usually have optical connected and for best results this would be my first choice.
Some have wireless back speakers to allow for easier installation.
RCA RT2781BE 1000W Home Theater System with Bluetooth This unit has two optical inputs and one digital input.
This is an inexpensive surround sound speaker system that should connect to your Panasonic TV optical output. Very available and I wanted to give you at least one option. Wires etc are a mess but the surround sound can be amazing. I would check all the reviews if you decide to go with this type of audio system. They can be confusing and in your case you need to have input control of volume with optical.
The following link is the manual for this particular Home theater System.
http://rcaav.com/wp-content/uploads/2014/11/RT2781BE_IB_0708.pdf
These audio systems can be very expensive. Less expenesive sorround can still provide great listening results.
Hope this helps?
Mar 03, 2016 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Panasonic plasma tv TC-TC-p42gt25. The power will
Contact any service technician or the authorized service centre for Panasonic. http://electronicshelponline.blogspot.com/
Oct 13, 2014 | Televison & Video
How do I get digital audio out from a panasonic panel to optical in on a yamaha amp
The TC-L55E50 has an optical output located on the rear of the TV. Simply connect the optical cable from the TV to the amplifier.
Mar 23, 2014 | Panasonic 55 inch VIERA 1080p 120hz LED TV...
My Panasonic TCP42GT25 turned off by itself and won't turn back on. The power source light is blinking 4 times and then pauses. any ideas on how to fix this? thanks.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 23, 2013 | Panasonic 42" Class Viera TC-P42GT25...
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
I have a Panasonic TC-P42GT25 tv that won't turn on. the power light blinks 4 times
4 blinks Power SOS P Board.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 22, 2012 | Panasonic TC-P42GT25 42" 3D Plasma TV
Panasonic plasma tv screen flashing
Good day!!!!
Commonly that trouble is cause of faulty capacitors on power supply board...
Please follow this step on how to fix that problem on your own..
  1. Open the back cover of your TV.
  2. Look at the power supply board..Its normally connected to the power cord..
  3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
  4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
  5. Some of the capacitors not bulged so its better if have a capacitance meter..
I hope this solution will be helpful...
Thanks for using fixya...
Nov 07, 2011 | Panasonic TC-P42GT25 42" 3D Plasma TV
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
I just bought a Panasonic plasma tv model TCP50S2 and I can't seem to get my Kenwood receiver to work with it. Do I need to set the remote to the Panasonic tc? If so does anyon know the code number? I...
I assume you want the TV sound through the receiver?
You need to connect the TV digital out to the receivers digtal in.
This is probably an optical connection.
Then you need to switch the receiver to the correct input. You may also need to tell the receiver what kind of connection is made: Optical or coaxial, if it doesn't detect this automaticly.
Sep 22, 2010 | Kenwood VR-705 Receiver
27 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
