Question about Kenmore Dryers
Kenmore dryer start switch - Kenmore Dryers
Replacing start switch on kenmore dryer
If you order the new Switch from sears parts direct.... Then when you replace the switch, make sure you unplug the dryer before you take the front panel off. Replacing the switch is quite easy... 4 screws total.
Jul 17, 2014 | Kenmore Dryers
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
After 500 kenmore dryer is done drying the dryer won't shut off
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Nov 06, 2010 | Kenmore 500 6952 Dryer
Kenmore dryer will not start. is it the door
since to push button is a contct relay,
i would suspect, the door switch first
Oct 13, 2009 | Kenmore 62602 Electric Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
I think my dryer finally stoped
Inspect the start switch and the door pressure switch as well. if both switches check out OK, replace the timer/control device.
Jun 03, 2009 | Kenmore 700 6972 Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Dryer switch works but dryer does not start
You have a bad motor.
Buzzing and not starting.
Feb 24, 2009 | Kenmore Dryers
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
